Aldi bargain laser level
Home Forums The Tea Room Aldi bargain laser level
Viewing 25 posts - 1 through 25 (of 91 total)
  • #35542
    Ian Johnson 1
      @ianjohnson1
      #418307
      Ian Johnson 1
        @ianjohnson1
        I love a bargain and this morning I picked up this laser level and tripod for £3.49 at the local Aldi store. Should be £14.99. It's not very sturdy but could come in handy as a camera tripod, just needs a little thread converter making from the weird 5/8" x 13tpi to 1/4" x20tpi. UK only they must be getting rid of the stock I think.20190711_130928.jpg
        #418380
        old mart
          @oldmart
          It would be a good buy at the recommended price, but £3.49 is brilliant.
          #418390
          JC54
            @jc54
            Last week picked up two pairs of work trousers reduced at Aldi. £2.99 a pair…. well worth looking at their reduced stock.. John
            #418391
            Barnaby Wilde
              @barnabywilde70941
              Laser levelling caused a revolution in sooo many areas of my life, I remember authorising the purchase of a site level for £18k back in the 80's.
              Forgive me, but how does this qualify as a laser level?
              The laser will point a straight line but it seems to rely on the good 'ole bubble in the glass.
              What will happen when I rotate it 180deg ???
              #418393
              Nick Clarke 3
                @nickclarke3
                Posted by JC54 on 11/07/2019 20:25:34:
                Sadly, after a lifetime of over indulgence, they do not keep them in my size ………. !
                #418402
                Ian Johnson 1
                  @ianjohnson1
                  Posted by Barnaby Wilde on 11/07/2019 20:27:14:
                  £18,000!!!! Wow! Quick question is the 5/8" x 13 a standard thread for survey equipment?
                  The instructions are pretty good as to getting it level, but I'm not bothered because I am pretty certain I won't be using it as a laser level! For £3.49 I got a cheap and cheerful tripod which I can use for my camera or phone, and a spirit level (with a built in laser beam!) and the bubble has a built in magnifier too which is cool.
                  Last week they had the last one of their table top band saws in a battered box, I was going to ask the price but I haven't got the room for a band saw. It probably would have sold for 20 quid or so too!
                  Ian
                  #418405
                  Barnaby Wilde
                    @barnabywilde70941
                    Posted by Ian Johnson 1 on 11/07/2019 20:53:06:
                    Ian
                    For £3.49 you have a definate bargain & YES, in the 80's I clearly remember authorising the purchase of an £18k laser level.
                    5/8" X 13 thread ??? FIIK ???
                    I've just bought a 300mm 'magic arm' to mount my wildlife cam. It cost just a few pence more than your tripod, yet I don't have anything useless attached to the purchase to throw away?
                    #418412
                    Ian Johnson 1
                      @ianjohnson1
                      Thread mystery solved! I checked it again and paid a bit more attention this time! It's actually a very bad cast plastic M16 x 2mm pitch at 15.25 mm dia nowhere near 16mm or 5/8" diameter come to think of it! dont know
                      I wrongly assumed tripod fittings were imperial thread sizes like camera mounts. Although I am pretty certain I machined an adaptor for theodolite survey posts, which were used to check a massive bridge being built locally, which had a 5/8" UNC stud on top of them to accept a 1/4" x 20 camera mount many years ago.
                      Ian
                      #418423
                      Paul Lousick
                        @paullousick59116
                        Its a laser pointer with a bubble level and not a precision instrument if you only rely on the bubble.
                        I used one to determine the levels for the storm water drainage piping around my house and because it was on fairly flat land, could only achieve a fall of 1 in 100. Prior to using the laser, I used a length of clear plastic tube, filled with water to mark datum points at several positions around my house and used these points as targets for aligning the laser. Then I could swing the laser between the datum points and measure the depth to the trench for the water pipe.
                        After the pipes were installed, a council building inspector told me it had to be checked by a certified surveyor. Luckily the cheap laser level and water filled tube did their job and the project was passed.
                        Paul.
                        #418427
                        Bob Stevenson
                          @bobstevenson13909
                          Aldi do have bargains from time to time but this set of rubbish is not one of them…even at 3.49 it's a waste of money and there is ZERO chance of either 'eve; or 'tripod' ever being used for anything meaningfull……..
                          ……….If you are desperate to spend money in Aldi while herself is gtting the groceries then do yourself a favour and buy the set of crochet hooks for £2.99 as there is at least a chance that they may come in handy at some point.
                          #418577
                          Ian Johnson 1
                            @ianjohnson1
                            Yes it is rubbish but I suppose we all buy some rubbish at some point in our lives, last week I bought a pack of 'Deluxe' biscuits … I ate one and they were disgusting so the rest went in the bin! 3 quid wasted! I can guarantee the tripod and level will last a lot longer and be more useful than the biscuits, and probably taste nicer too! laugh
                            #418729
                            andrew lyner
                              @andrewlyner71257
                              Posted by Paul Lousick on 11/07/2019 23:18:46:
                              That method is excellent wherever it can actually be used (i.e. where there's a useable low point for the U. Gravity is delightfully consistent and it doesn't matter what mix of tube diameters you use.
                              I was given a similar laser 'level' years ago and it is cheap and nasty BUT still useful and better than trying to do the same thing with a laser screen pointer. When the alternative is bits of saggy string and wooden pegs, it makes itself useful. And I can always check and re-check.
                              Members really should be more realistic when expecting 'high professional standards' in every aspect of DIY (unless they have money to burn). Cupboards full of posh equipment that was used once and never since, are really not good value for money, Hire shops can cost you a lot but it's often the best way to get use of fancy gear. You just have to get over feeling offended by the cost.
                              #418749
                              Sam Longley 1
                                @samlongley1
                                Paul.
                                That brings back memories.
                                When I was 10 years old my fathers foreman ganger used to let me sight down the boning rods when drain laying.
                                Salt glazed drains with cement joints..
                                Datums were set with a Cowley level.
                                Still would not mess about with a laser if there was 2 of us.
                                Still got the dumpy level & staff he let me buy for my own use when I was 16. An antique now I suspect.
                                If a building surveyor told me that i had to have a "certified surveyor" to check my drains I would have told him to get stuffed- (Regardless of the fact I am qualified anyway, it would not matter)
                                One of the questions I used to ask site foremen when interviewing them was, "Can you use a dumpy level" Answer " yes" – OK
                                Do you know how to check it for accuracy? That used to stump some of them & I suspect that lasers, when hired, borrowed etc. would not necessarily be accurate. Most would just assume they are. But hired equipment gets abused.
                                I have never used one in anger; but if i did I would know how to check it.
                                I wonder if others have had the problem- is it an issue with lasers?
                                So here is a question for you.
                                How would one check a "hired in" laser for accuracy prior to use?
                                Edited By Sam Longley 1 on 14/07/2019 07:30:33
                                #418750
                                RMA
                                  @rma
                                  I wish posters would refrain from including a group of capital letters in their post which mean absolutely nothing to me! Am I the only one that doesn't understand these things. I'm assuming it's 'text speak', but this isn't texting is it?
                                  #418755
                                  Paul Lousick
                                    @paullousick59116
                                    Sam,
                                    I only had a home builders certificate and had to comply with the council inspectors request, otherwise they would not approve the completion of our house. Sometimes you have to do as they say and keep quiet. Fortunately I knew of a surveyor who lived nearby who did the job at a fair price.
                                    Yes, the laser is a cheap and nasty piece of equipment but if used to its level of precision (pardon the pun) can be useful. I have also used it to set the heights for the boundary fences. Better that a string line which sags in the middle. One of its main faults is that it is hard to see the laser dot in bright light. OK on a white background if shaded from the sun.
                                    Paul
                                    #418756
                                    not done it yet
                                      @notdoneityet
                                      OK, OK, OK.
                                      I thought everyone would understand that particular grouping of two letters!
                                      BUT, it is still good to befuddle those that just reply without really having a clue of the topic under discussion. But, yes, acronyms should be accompanied by the real full wording on the first occasion of use. Now, how often have I needed to back-track in a report because I missed the first occurrence? More times than I could possibly remember…
                                      #418763
                                      RMA
                                        @rma
                                        Yep, I understand OK, but what the hell does FIIK mean?
                                        #418764
                                        Daniel
                                          @daniel
                                          Posted by RMA on 14/07/2019 08:20:34:
                                          Google Urban dictionary should help.
                                          HTH & ATB, wink
                                          Daniel
                                          #418765
                                          Clive Hartland
                                            @clivehartland94829
                                            Standard Instrument securing thread in the UK is 5/8" x 11 Tpi. Whit. form. There is another US style at 11/16 " x 11 Tpi. This is mainly used in Aircraft building, test equipment.. Also some military applications, just to be awkward I think.
                                            #418766
                                            Nicholas Farr
                                              @nicholasfarr14254
                                              **LINK** Hi RMA, notice the wording in brackets, helps to make your own mind up.
                                              Regards Nick.
                                              #418770
                                              Brian Oldford
                                                @brianoldford70365
                                                Posted by Clive Hartland on 14/07/2019 08:29:02:
                                                That's the wonderful thing about standards. You can have as many as you want. laugh
                                                #418771
                                                RMA
                                                  @rma
                                                  Thanks for the pointers folks, but I'm assuming most of us on here are beyond a certain age and don't use trendy 'language' obviously found to be necessary by the younger population. I certainly don't intend to learn it now, I'll just ignore the posts that contain it! There must be better ways to recapture your youth, another topic maybe for the tea room?
                                                  Apologies for going off topic.
                                                  #418778
                                                  Brian G
                                                    @briang
                                                    Posted by RMA on 14/07/2019 08:38:09:
                                                    At 60 I guess I am one of the younger population, but wonder how many on this forum actually pre-date these acronyms? Famously "OMG" was used by Admiral Fisher in 1917 (although he helpfully put "Oh! my God" in brackets afterward), FUBAR and SNAFU go back to the 1940s, and RTFM to the late 70s, predating even Usenet and FAQ.
                                                    #418794
                                                    andrew lyner
                                                      @andrewlyner71257
                                                      Posted by Nicholas Farr on 14/07/2019 08:30:46:
                                                      Regards Nick.
                                                      In the old days, one would need to phone a friend for such information – or walk over to ones Britannica collection. Nowadays, without getting up from the computer, you can go to Google and type " **** means".
                                                      I had not come across that particular acronym before (a sheltered life) but the bowdlerised version turned up at the top of the search returns page.
                                                      IMO, Google rocks for all ages/
