Posted by Richard brown 1 on 09/06/2018 20:44:11:
The advice I was looking for is what is the best or simplest method to control the primary side of the transformer in order to vary the heating on the secondary side.
…Rich
Unfortunately I don't think there is a straightforward safe way of controlling power input to the primary of a transformer without modifying the coil or front-ending it with another transformer like a variac – not cheap!
The most usual solution is to control power output by tapping the secondary side of the transformer and/or by combining a number of secondary windings. Or by moving the magnetic core. I assume you are reusing a transformer that doesn't have either option!
A dimmer or drill-controller might work, but I wouldn't do it. They work by chopping the mains up making sharp waveforms that aren't really compatible with transformers. Chopping produces voltage spikes that can puncture a transformers internal insulation.
In total plonker territory, you could make a rheostat from a bucket of salt water and two electrodes. Lowering the electrodes into the water varies the resistance and could be used to control power fed to a primary. This method was much used to control lights in the early days of electrified theatres. Didn't last long because of the many electrocutions, gassings, fires and operational inconveniences. DON'T! Buckets of water were soon replaced by properly designed wire-wound rheostats, much safer, but expensive and difficult to find today.
The other thread mentions using filament light bulbs as resistors. That's a possibility, but designing and wiring up safely requires a level of skill. It also mentions rewinding Microwave Oven Transformers. The construction of the examples I've looked at all made it easy-ish to remove the EHT winding and replace it with a home-made secondary. Winding a new secondary is straightforward because you only need a few turns of thick wire, and you can tap it every turn if you want. (Professional units all seem to have three taps between 2v and 5v.) You don't touch the mains primary: wiring it up safely still requires care (box, fuse, switches, earthing etc. etc), but there's less to get wrong.
Be quick though – transformers in microwave ovens are disappearing in favour of a switch-mode EHT supply that cannot be adapted.
Usual warnings about messing with mains electricity! In particular be sure you understand your limitations. Fools jump in where angels fear to tread. Confidence is no substitute for knowledge and experience.
