Hi Alex, very sorry to hear you feel you're going round the houses! As a recent beginner myself, who still has a lot to learn, I know exactly what you mean. Ask an apparently simple question, and you get contradictory answers, and a bit of a grilling.
Don't despair. The forum is keen to help, and members – notably Jason – are trying to clarify what exactly your need is.
Quite a common newcomer mistake is believing that high-accuracy is essential and the more accurate the better. My idea was that a high-quality machine would be capable of anything I required of it, therefore I needed only the best. In my case, I was quite wrong. What I need is ordinary: for my purposes machines in the 0.02mm region are 'good enough'. It's because most of my work is roughing out, and – if needed – better than 0.02mm can be achieved by supplementing the machine with other techniques. My perception is most Model Engineer's are like me, working to about a thou or 0.02mm. Steam engine and many clock makers often recommend even slacker fits, seeing problems in overly tight constructions. It depends on what you are making.
The reason excessive accuracy is a mistake is that it moves engineering costs into a different zone. Machines that can do 0.02mm are easy to find and relatively cheap. Better machines are generally moving into the tool-room class, accurate, but with many disadvantages: small work-holding capacity, high-cost (BCA about £12000 new#), difficult to find, big and heavy, high-maintenance, and vulnerable to wear. It's very bad to tell someone doing ordinary light precision work in a small shed he needs an expensive high-accuracy machine when a £400 mini-mill would do.
Trouble is Model Engineering is a very broad church. While I believe most of us do very well at 0.02mm/1 thou, there are many working to higher standards, some of them for professional reasons. Your question landed on the boundary, hence requests for clarification and guesswork about your real requirement. We don't want to recommend a Chinese mini-mill when something like a BCA is needed, or vice versa. As a £400 chinese mini-mill isn't as well made as a £12000 jig borer, one answer could get you an mill that won't do what you need, the other answer could be unaffordable.
From what's emerged it sounds like you really do need a small jig-borer. Not sure how much heavier they are than a mini-mill, but you should in any case check your proposed stand is good and stiff. There's little point in mounting a high-quality machine on a wobbly base. When working to high accuracy everything matters!
We want you to succeed without breaking the bank.
# Can Jig Borers like the BCA still be bought new? The £12000 price I quoted is at least 10 years old and I've a vague recollection it was mentioned in an article about closing down.
Edited By SillyOldDuffer on 25/07/2019 09:44:28
