ACME thread identification question.
Home Forums General Questions ACME thread identification question.
Viewing 14 posts - 51 through 64 (of 64 total)
  • #428986
    old mart
      @oldmart
      Thread rolling is a specialised process, which most firms would sub out to the experts.
        Posted by S.D.L. on 14/09/2019 16:52:51:
        Halifax Rack and Screw make precision leadscrews, Used to serve the machine tool industry.
        I know they will also make Ba$tard sizes as where I work they used to make us a 16mm x metric pitch ACME in stainless steel.
        Perhaps you could explain then, Steve [please]
        Why would anyone choose to specify 16mm x some metric pitch in ACME form rather than Metric Trapezoidal ?
        [my brain hurts] … Is it just to make it difficult for customers to second-source spares ?
          Posted by old mart on 14/09/2019 18:58:08:
          But why would those experts want to roll an ACME thread-form to Metric dimensions.
          True ACME is [to the best of my knowledge] exclusively specified in Imperial units.
          … If I am wrong; would someone please tell me
          Pete Rimmer
            @peterimmer30576
            ACME is standardised in imperial units but the form can be used for metric leads. If you were cutting the thread to a metric lead you'd have to convert the lead to inch pitch then grind the tool nose width appropriately. However, if you were rolling that metric thread you'd have to have a non-standard set of rolls manufactured.
            Since the vast majority of the early Boxfords were inch screws I wonder if they had the metric threads cut but the inch ones rolled for cost purposes?
            #429011
              Posted by Pete Rimmer on 14/09/2019 20:32:26:
              < my emboldening >
              That's what I was wondering, Pete
              … hence my hope that someone might know for sure how the metric screws were made.
              Edited By Michael Gilligan on 14/09/2019 21:20:37
              #429013
              Pete Rimmer
                @peterimmer30576
                I guess you'd need to find an ex-employee from the factory for that, or a drawing.
                BTW I had an Denford TDS1 and the cross slide thread on that was clearly cut (or at least finished) with a die. The marks where the die stopped were plain to see.
                #429015
                S.D.L.
                  @s-d-l
                  Posted by Michael Gilligan on 14/09/2019 19:01:53:
                  I always put it down to one of my predecessors being stupid. I was never able to find out why but my guess was they didn’t know about trapezoidal.
                  Sometimes things conspire against you I designed a pneumatic cylinder 150mm Diameter with a screw on end, It was supposed to be 150mm x 2mm or something similar, had been told we had got the internal and external tips, but we hadn’t got the Internal so it was done 150mm x 12 TPI Whit. I calculated the dimension for 3 wire on the external thread and we made that fist then did the internal thread to fit.
                  In most of these cases its ignorance or expedience.
                  Steve
                  #429016
                  S.D.L.
                    @s-d-l
                    Posted by Pete Rimmer on 14/09/2019 21:44:44:
                    How are you sure it was a die? Threads cut with an Anjest attachment have a run out like a die as do modern CNC threads no need for an undercut with either.
                    Steve
                    #429017
                      "In most of these cases its ignorance or expedience."
                      smiley … nice summary, Steve.
                      Edited By Michael Gilligan on 14/09/2019 22:07:13
                      #429018
                      S.D.L.
                        @s-d-l
                        Posted by Michael Gilligan on 14/09/2019 19:07:15:
                        A lot of leadscrews are cut by thread wirling, The most accurate are ground.
                        Steve
                        #429019
                          Posted by S.D.L. on 14/09/2019 22:09:11:
                          Yes, Steve : But the Boxford drawing that Pete posted explicitly states 'Plunge Roll'
                          S.D.L.
                            @s-d-l
                            Posted by Michael Gilligan on 14/09/2019 22:29:53:
                            Yes but that’s for imperial ACME, they may have done the metric by another method?
                            Steve
                            #429021
                              Indeed, Steve yes
                              That's why I've been banging-on about wanting to know how it was made.
                              It's of no relevance to me personally … just an interesting puzzle.
                              Pete Rimmer
                                @peterimmer30576
                                Posted by S.D.L. on 14/09/2019 22:04:13:
                                Steve
                                I'm not sure, just how it appeared to me. I figured if it was done with an auto knock-off device then the marks would be right at the end of the thread. This appeared to be cut further along then finished slightly short of the end. I only mention it as a matter of interest really.
