ACME agony
ACME agony
Home › Forums › Beginners questions › ACME agony
Viewing 25 posts - 1 through 25 (of 28 total)
  • #265352
    Robin Graham
      @robingraham42208
      I'm trying to turn a 4 tpi external ACME stub thread in brass using a home-ground HSS tool. It isn't working. Horrible chatter even with a steady behind the cutter.
      If I use my cutter like a parting or profiling tool, going in straight in, it works well, so I'm thinking my problem is (given the steep helix angle) that I haven't got the side relief right. Is that a reasonable conclusion would you say?
      Rob
      #8372
      Robin Graham
        @robingraham42208
        #265353
        Ady1
          @ady1
          I have only done a square thread a couple of times but I recall that I did it in stages
          Stage 1 was with a pointy tool to create a normal deep thread, then used a square tool for the rest of the job.
          #265357
          John Reese
            @johnreese12848
            If you can plunge the tool but not thread with it you probably have insufficient front clearance. 4 TPI requires a pretty wide tool nose. A small lathe may not be rigid enough to handle that width of tool without chatter. As Ady1 said, use a v tool to do roughing cut, then finish with the Acme tool.
            #265358
            MW
              @mw27036
              I would say thats a fair guess, the profile of the tool needs to be ground to match the form of the spiral/helix angle because on the deeper cuts you may not be able to clear the threads.
              An acme thread is slightly more forgiving to cut than say a truly square thread, so i'm not sure if thats true or not.
              Michael W
              Edited By Michael Walters on 08/11/2016 05:04:10
              #265359
              Hopper
                @hopper
                Yes, it sounds like the tool has insufficient clearance on the leading side. You don't state the diameter of thread, but a 4tpi thread is going to have a steep helix angle. And the angle is steeper at the root of the tooth so the tip of the tool needs more clearance than further out.
                You can work out the helix angle by taking the circumfrence of the thread, at the root, and the pitch (.250" in this case) and laying it out as a triangle. For instance a 1" thread will have a circumfrence of about 3.14". So a right-angle triangle with one side of 3.14 and one of .250 gives you a helix angle of about 4.5 degrees. So if you want to have say 5 degrees clearance, the tool must be ground at 9.5 degrees, or call it 10. But take the root of the tooth which has a diameter of .750 and your helix angle is more like 6 degrees, requiring a tool with more like 11 degrees clearance ground on it, and so forth. With a larger tool bit like used for 4 tpi you should be able to measure the angle with a protractor gauge etc.
                Another thing that helps when cutting Acme therads is to set the top slide at slightly less than half the thread angle just like you do for a BSW or UNC thread. So for ACME you set the topslide to 13.5 degrees, that is 13.5 degrees from the cross slide axis, not the main lathe axis. This way when you feed the tool in, most of the cutting is done on that one leading edge, considerably lessening the cutting load. To get the right amount of infeed with the topslide set over at 13.5 degrees, you just use the standard thread depth, plus 2.8 per cent.
                Or you can get the same effect by leaving the topslide in the normal position parallel to the lathe main axis, but for every 10 thou you move the tool bit inwards, use the top slide to move it 2.5 thou towards the leading edge of the tool. IE, top slide moves one quarter of what the cross slide moves. This shifts the tool at close enough to 13.5 degrees but has a couple of advantages over off setting the top slide. One is that thread depth is read directly off the cross slide dial, no need for adding the 2.8 percent etc (or multipy by 1.028 for duffers like me). The other, big advantage, is that at the final cut stage, or close to it, the top slide can be used to move the tool bit just a thou or so in one direction to take a small clean up cut along that cheeck of the thread, then moved just a thou or so in the other direction to take an equally tiny clean up cut along the other cheek of the thread.
                Also, assuming that for brass you have no top rake or side rake on the tool bit. IE, top of tool bit is dead flat so there is no tendency for it to "self feed" either inwards or sideways. If you want to get really picky , top rake should be flat relative to the helix angle of the thread. One way to do this is to grind the toolbit out of round HSS then rotate it in its holder by the helix angle of the thread. I've been meaning to try this for years but always end up usiing my standard square HSS stock and grinding the extra angles on the one side.
                #265361
                John Hinkley
                  @johnhinkley26699
                  Or get your credit card out and buy an insert! Kennametal do one in the NA series for 4 tpi. I bet it ain't cheap, though.
                  not done it yet
                    @notdoneityet
                    This topic (in several different threads) has now been going on for over a month. Do the easy option. Partly cut the thread in the acetal and fully form it by 'heat 'n squeeze'.
                    #265366
                    John Hinkley
                      @johnhinkley26699
                      Not diy,
                      All very well if you're cutting the thread in acetal, but Robin asked for help for cutting brass.
                      Raymond Anderson
                        @raymondanderson34407
                        What Ø is the thread ? The Helix angle will change with the Ø For instance if the major Ø is 25mm the helix angle should be 5.046° for 35mm major Ø it would change to 3.520°. It does indeed sound like it is rubbing on the front edge.
                        Vardex are threading insert specialists,and they would have a specific insert for you, but they are spendy.sad
                        #265371
                        mick
                          @mick65121
                          You've chosen the most difficult thread to cut, but a few suggestions. use a square tool the width of the bottom flat. Take the cut 0.020'' below the minor diameter. Then with a ACME form tool cut the flanks, thereby avoiding cutting the full form. Hope that helps.
                          #265377
                          John P
                            @johnp77052
                            "I'm trying to turn a 4 tpi external ACME stub thread in brass using a
                            behind the cutter.
                            side relief right. Is that a reasonable conclusion would you say?"
                            First of all why would you make a leadscrew in brass ,at 5/8 inch od
                            with a .085 in thread depth ends up with a root diameter of 0.455 inch
                            with a 4 tpi thread ,hardly suprising that you are having problems.
                            Have a read of the recent article in MEW 241 to 243  Milling leadscrews these sort
                            of problems are history ,job set up ,full depth in a single pass , set it
                            running walk off and leave it, come back when its done.
                            Edited By John Pace on 08/11/2016 09:36:54
                            #265401
                            John Stevenson 1
                              @johnstevenson1
                              Robin, if you have a spare 1/2 hour, pop down and I’ll either do you one or show you how to do it.
                              #265405
                              Hopper
                                @hopper
                                Posted by John Pace on 08/11/2016 09:34:45:
                                5/8" OD? Where did that come from? With a root diamter of .455", you would have a helix angle of 28 degrees or so. NO WONDER the side of the tool is rubbing. You need 33 degrees of clearance there. Definitely make tool from round HSS and turn it sideways by 28 degrees.
                                Lead screw? I thought the OP said it was a "stub thread"? I had visions of something an inch or two long.
                                Perhaps the OP could post a pic of what you are doing?
                                Edited By Hopper on 08/11/2016 11:44:43
                                Edited By Hopper on 08/11/2016 11:49:39
                                #265415
                                John Stevenson 1
                                  @johnstevenson1
                                  Robin asked how to turn one as he doesn't have a milling machine and therefore also doesn't have all the extra bits needed that are covered in MEW 241 to 243.
                                  Why do people answer a question that hasn't been asked. ?
                                  #265416
                                  not done it yet
                                    @notdoneityet
                                    You clearly missed my point. Do look back at the (several?) related posts from a month back. It is all to do with a leadscrew half nut for a wood turning lathe, I am sure. Existing nut is delrin.
                                    #265433
                                    Robbo
                                      @robbo
                                      ndiy
                                      But Robin is cutting an external thread. Not a feed nut or half nut.
                                      #265437
                                      John Stevenson 1
                                        @johnstevenson1
                                        Does it matter what he's doing or rather was doing ?
                                        He's asked a question and as usual over half the people have answered a question he never asked.
                                        #265439
                                        Raymond Anderson
                                          Don't know where the 5/8" Ø came from, Robin never mentioned that., or a leadscrew [surely not at a stub profile !!! ] Anyhow ,here is the thread data for,
                                          5/8" stub Acme, at 4 TPI. Single start. [ makes me shake me head just looking at it !! ]
                                          Lead 0.250" Effective Ø 0.5437" , Minor Ø 0.4550" profile height 0.0850" Helix angle 8.327°. Vardex states that is a non standard insert [ if you want to go down that route be prepared to part with a lot of cash ]
                                          Best rough it out with a "v " then finish off with the tool ground to the correct helix angle. .best of luck….
                                          #265458
                                          John Reese
                                            @johnreese12848
                                            Hopper suggests calculating the lead angle based on the circumference of the thread. Bear in mind that the lead angle changes according to how deep in the thread form the circumference is taken. The minimum value of lead angle would be measured at the outside diameter. The maximum value is obtained at the minor diameter. The most critical location on the tool for clearance angle is at the tip of the tool (it cuts to the minor diameter). I calculate the lead angle at the minor diameter and grind my tool so the side clearance exceeds the lead angle by several degrees.
                                            #265489
                                            mark costello 1
                                              @markcostello1
                                              An easy help for this problem is to color up the tip of the cutting tool with a Sharpie-magic marker and see where the tool tip is rubbing.
                                              #265515
                                              John P
                                                @johnp77052
                                                Posted by Robin Graham 08/11/2016 01:20:16
                                                I'm trying to turn a 4 tpi external ACME stub thread…
                                                Presumably this is still in connection with this earlier thread as if he
                                                had already solved this earlier query we would not be seeing this
                                                thread "ACME agony".
                                                Here is the first few lines of that post note the 5/8 x 4 tpi and also
                                                the unwisley part.
                                                Screwcutting Acme threads
                                                Posted by Robin Graham 15/10/2016 23:27:44
                                                Perhaps unwisely I've offered to help someone out by cutting an acme thread
                                                in a half nut for a woodturning lathe restoration project. Options would be to make
                                                a tap (the leadscrew thread is apparently 5/8 x 4tpi)…
                                                Posted by John Stevenson 08/11/2016 12:16:08
                                                in MEW 241 to 243.
                                                Well we have all been there at some time with the lack of know-how
                                                and equipment.
                                                About 40 + years ago before i even had any machinery i was building
                                                and flying model aircraft ,a particular project required a fan ,the place i
                                                worked at that time used to make all sorts of things in connection with
                                                the auto industry.
                                                I went and asked someone in a department that dealt with such things
                                                to try to (borrow) one ,the guy said he had nothing suitable and suggested
                                                that i make one,i said i didn't know how ,he said go and learn .
                                                This was a pivotal moment for me from which i have never looked back.
                                                Perhaps the OP has just taken on a job that he had no chance of doing,
                                                these sort of things are only learnt in time sometimes just by doing.
                                                One of the problems with forums is they can provide a wealth of information
                                                that is completely lost on those who are just starting.
                                                Posted by Raymond Anderson 08/11/2016 14:41:36
                                                Raymond
                                                The 5/8 inch came from that earlier post .I also worked out the helix angle
                                                and all of the other dimensions and got exactly the same figures as yours.
                                                Hopper had obviously forgot to apply Pi x d in the calculation to get to
                                                28 degree as tan .250/.455 = 28.78 degree.
                                                Placed in album "Leadscrew" American Standard 29 deg Stub Thread
                                                tables.
                                                Hope this is of interest.
                                                John Stevenson 1
                                                  @johnstevenson1
                                                  Posted by John Pace on 08/11/2016 20:36:41:
                                                  and equipment.
                                                  the auto industry.
                                                  John, all all fairness i feel that some of us with skills and decent workshops thing it's easy and anyone can do it.
                                                  OK going away and learning but no amount of book reading will get over the fact when you look in your workshop you are missing a milling machine.
                                                  OK you could convert your lathe to a mill or even a thread mill but end of the day a screw cutting lathe is good for ? Screwcutting, and has been for 200 ? odd years so why reinvent the wheel.
                                                  #265544
                                                  Hopper
                                                    @hopper
                                                    Posted by John Stevenson on 08/11/2016 12:16:08:…
                                                    42.
                                                    #265545
                                                    John Stevenson 1
                                                      @johnstevenson1
                                                      LOL but is that 6 or 2
