Hello, MichaelG, good evening.
This is the second and last parte of my text:
I think that a reduction to 1/5th is not possible. If we consider that the side panels of the structure of my shaper machine is 180mm wide and 280mm high, a reduction of 1/5th result in 36mm wide by 56mm high. I think the other components destined to suffer stress, even for brass or aluminium, for a so small size machine would have to be very small and will not support the cutting effort.
Also the resulting size (around 10mm) of the gap between the two panels where the rotary motion is converted into reciprocating motion would be of a size which would not fit the mechanics required.
I think, whatever the shaper machine you'll get, so that it produces high-precision surfaces as you want, it will benefit from a movement of very regular nature which, I think, only a system that uses wheels (with engine or hand crank) will produce.
MG: Sorry … I forgot to compliment you on the Movie.
DC: Do not worry. Thank you for your kind words.
Let me tell you that I have not had conditions to test the cutting capabilities of my shaper machine because the fire in my workshop. However you can look up some movies on Youtube by Mr. Rick Sparber. He built a shaper machine strictly following the book of Mr. Gingery and shows it on Youtube cutting some metal.
Mr. Rick Sparber helped me with important views in the construction of my shaping machine.
I would like to know that my poor mastery of the English language has allowed me to share with you my opinions.
Hope this helps
Dias Costa
Edited By dcosta on 23/10/2013 00:04:26
