A little ampification on the nature of pipes:
1) Pipe is made of a long hole surrounded by metal or plastic centred around the hole.
2) All pipe is to be hollow throughout the entire length.
3) The ID (Inside Diameter) of pipe must not exceed the OD (Outside Diameter) — otherwise the hole will be on the outside.
4) Pipe is to be supplied with nothing in the hole, so that water, steam or other stuff can be put inside at a later date.
5) Pipe is normally supplied without rust; this can be applied at the job site. NOTE: Some vendors are now able to supply rusty pipes. If available in your area, this product is recommended, as it will save a great deal of time at the job site.
6) All pipe over 500 ft (150 m) in length should have the words "LONG PIPE" clearly painted on each side and end, so that the contractor knows it's a long pipe.
7) Pipe over 3 miles (3.3 km) in length must also have the words "LONG PIPE" painted in the middle, so the contractor will not have to walk the entire length of the pipe to determine whether or not it is a long pipe or a short pipe.
8) All pipe over 6 ft (1.83 m) in diameter must have the words "LARGE PIPE" painted on it, so the contractor will not mistake it for small pipe.
9) Flanges can be used for joining pipe. Flanges must have holes for bolts, quite separate from the big hole in the middle.
10) When ordering 90 or 30 degree elbows, be sure to specify left-hand or right-hand, otherwise you will end up going the wrong way.
11) Be sure to specify to your vendor whether you want level, uphill or downhill pipe. If you use downhill pipes for going uphill, the contents will flow the wrong way.
12) Couplings should have either right-hand or left-hand threads, but do not confuse the threads otherwise, as the coupling is being screwed on one pipe, it can unscrew from the other.
13) Pipes shorter than 1/8 in (3 mm) are very uneconomical in use, requiring many joints. They are sometimes known as washers.
14) Joints in pipes for pumping compressed air must be air-tight. Those joints in pipes for water, however, need only be water-tight.
Jim
