1040 Steel
1040 Steel
Home Forums Materials 1040 Steel
  • #50742
    Dave Tointon
      @davetointon92281
      G’Day all,
      I went to my steel supplier after a foot of 75 mm bright mild steel, Making a ball turning attachment. He only had, as he termed it 1040, apparently a medium tensile stuff.
      It turned up nicely but I’m trying to mill a 16mm slot across the top and finding it a bit tough. I’m using an indexable TC tip slot drill lots of coolant but find anything over a 1mm cut is beyond the caapability of my round column Chinaman.
      2. Questions Please. Is 1040 good stuff and any tips on machining the stuff??
      Dave Tointon
      #29414
      Dave Tointon
        @davetointon92281
        #50747
        Julie
          @julie
          It is a standard steel basically it is EN8 in BS970 (1955) or 80M40 in the newer definitions of BS970.
          It is medium strength unalloyed steel.
          It is usually used for stressed pins and shafts
          It ain’t as easy to turn/machine as EN1 by a long way – if one looks at machinability indexes  EN1 is 100 whilst EN8 is something like 45.
          A good round tool – loads of suds etc and it turns OK
          With milling, lots of small cuts and a carbide tool is best.
          The big issue is that it is very heat treatable, so if you generate too much heat at the cutting surface it ends up hardened! – even a slight bit of heat and rapid cooling (such as the mass of the workpiece) and it is harder than the rest.
          Julie
          #50748
          KWIL
            @kwil
            A 1mm cut x 16mm dia is not a bad performance by any standard, just need more of them. How deep are you going?
            #50753
            Dave Tointon
              @davetointon92281
              Depth of slot is about 25mm. I’m basically winging it. When she looks right and the previous bit fits. then she’s right!!! I’d have thought that the machine would cope with at least an eighth of an inch cut
              Thank you for the advice
              Circlip
                @circlip
                Was going to ask if this is based on the Steve Bedair design? If so, if you look on the edge of the outside dia. of the turntable block, can’t you IMAGINE a hole drilled across the dia. (Say 15mmDia.)?? A couple of vertical saw cuts gets rid of MOST of the “Scrap” so you just have to clean up the slot.
                  Not unique but so many newer members will try to CLEAVE big lumps of scrap metal out with a milling cutter.
                  Regards  Ian.
                #50760
                  Or just drill a series of vertical holes to remove a lot of the waste
                  J
                  #50873
                  Dave Tointon
                    @davetointon92281
                    Thanks for the advice Circlip. I had thought of drilling a hole through the side but thought I’d have a go milling the complete slot. I have to keep reminding myself these days that the foreman won’t be breathing down my neck because the job is taking a long time.
                    Circlip
                      @circlip
                      Aye, and don’t forget, the FOREMAN ain’t paying for the cutters now.
                         Regards  Ian.
                    Home Forums Materials Topics
