Reply To: copper pipe for model engines
Home Forums Materials copper pipe for model engines Reply To: copper pipe for model engines
#138629
Jeff Dayman
    @jeffdayman43397
    I'm not sure about the UK but copper brake lines are absolutely not allowed on cars and trucks in Canada and USA. Any car or truck fitted with copper brake or fuel lines will not pass a vehicle safety inspection. The reason is that copper tubing is unsafe for hydraulic applications – it will work harden and develop cracks and leaks after repeated pressurization at hydraulic pressures (700 psi and up) and this effect worsens with normal shocks and vibrations in a car chassis.
    Only plated mild steel tubing or stainless steel brake tubing with an SAE rating for automotive use is allowed for hydraulic brake service on passenger vehicles and trucks in Canada and USA, with double flared ends and heavy wall compression fittings. In heavy equipment worldwide, all rigid metal tubing used for hydraulic systems is steel or stainless steel hydraulic tubing. Stainless mesh reinforced rubber tube may be used for flexible hydraulic lines. Copper is not allowed for tubing in heavy equipment hydraulic systems at all.
    For steam or water up to about 300 PSI, copper tubing is fine, but do use a heavy gauge tube for high pressure. When I worked in industry with copper piping in hot water heating systems we were taught never to exceed 400 psi working pressure in any copper pipe or tube as a general rule, as most copper pipe was rated for no more than 400 psi working pressure in North America. Actual burst pressure was far higher than 400 psi, but the material was de-rated to 400 psi WP at room temperature to ensure adequate safety factor.
    I'd ask your boiler inspector though before buying or fitting any piping, especially any that deviates in size from the published design for your engine's boiler.
    Just my $0.02. JD
    Edited By Jeff Dayman on 24/12/2013 00:03:36
    Edited By Jeff Dayman on 24/12/2013 00:04:41
