Optimum speed for a linisher belt?
Home Forums Beginners questions Optimum speed for a linisher belt?
  • #302696
    Andrew Tinsley
      @andrewtinsley63637
      I purchased a beautifully made linisher some 35 years ago! It doesn't have a stand or motor.
      I have sourced a new 1/3 HP two pole motor and I have a frame from the scrap box, so all I need is a switch, belt, 2 pulleys and a guard.
      So my query is what should be the optimum speed of a linisher belt? Knowing this, I can source the correct pulley ratio that is needed. Feet per second is the desired quantity or indeed metres per second!
      Thanks in advance,
      Andrew.
      #8753
      Andrew Tinsley
        @andrewtinsley63637
        #302707
        Clive Foster
          @clivefoster55965
          3M reckon around 20 to 25 m/s, say 3,500 to 4,500 ft / min in round numbers, for theirs but they claim much better abrasive performance than other makes.
          RJH give 6.5 m/s, 1,200 ft / min in round numbers as the belt speed for their Antelope band facers. As I recall matters their simple flat style bench mount linishers used a 1:1 pulley drive with a 1,440 rpm motor. Not sure on roller diameter. Probably 3 1/2" or 4" so 1,300 to 1,500 ft / min.
          Picador used to recommend a 1:1 pulley driver ratio when using a 1,440 rpm motor on their machines whose roller diameter was around 3" if I recall correctly. Comes out to around 1,130 ft/min. 1:1 drive worked fine for me on my Picador.
          So somewhere around 1,000 to 1,500 ft/min should work OK. Given the choice I'd go towards the low end.
          Clive.
          #302708
          Ian P
            @ianp
            I imagine the best belt speed varies with the job material and the type of abrasive.
            I do have the luxury of my linisher being driven by a variable speed motor and do frequently adjust the speed to suit what I am doing. At low speed with say, a fine belt its possible to get a part to a precise shape or thickness and keep the surface flat and square.
            You can probably do a quick calculation of what ready built linishers operate at just by seeing the motor speed rating plate and guestimating the pulley diameter.
            IanP
            #302718
            Andrew Tinsley
              @andrewtinsley63637
              Hello Ian,
              I don't have the luxury of a variable speed motor, so I am stuck with what I have, a 2 pole 2880 rpm motor!
              Thanks Clive, sounds as if I should go with around 1250 feet per minute. Now to go and find the diameter of the rollers!
              Thanks all,
              Andrew.
              #302754
              Ian S C
                @iansc
                not sure of the surface speed, but a belt sander is avialable to attach to a bench grinder(6" or 8&quot, right hand wheel side. Can't remember the size of the driving drum if that matters, could be around 75 mm.
                Ian S C
                #302760
                thaiguzzi
                  @thaiguzzi
                  Industrial linishers were generally or very close to 1:1, using 3000 (2850) rpm motors. Wheels generally around 10".
                  #302777
                  Journeyman
                    @journeyman
                    I have a Warco BDS460 belt sander / linisher. The motor runs at 2850rpm and drives a 60mm dia roller at 1:1
                    I dug out my old calculator and worked out that this is a belt surface speed of about 9m/s or roughly 1800ft/min
                    Andrew Tinsley
                      @andrewtinsley63637
                      Thanks everyone,
                      I should have enough info now, great helpful bunch on this forum!
                      Andrew.
                      #302831
                      Martin Connelly
                        @martinconnelly55370
                        Our work linishers have 2 speed 3 phase motors directly driving 200mm drums with a small degree of crowning. I have not looked at the motor speeds.
                        Martin C
                        #303165
                        Martin Connelly
                          I have checked the (Marpol) manual for an industrial linisher and it has speeds of 16.5 and 33 metres per second using a 3.37 kW motor running at 1400 and 2800 rpm.
                          Martin C
