TAPS, spiral or std
TAPS, spiral or std
Home Forums Beginners questions TAPS, spiral or std
Viewing 25 posts - 1 through 25 (of 53 total)
  • #295739
    petro1head
      @petro1head
      i am currently making a steel ball turning tool for my lathe.
      I need to tap two 2.5mm hols to hold the tool bit.
      I recently bought a set of Bergen taps, 3 taps per size, but to be honest on small holes i.e. M3 or M4 I often end up snapping the tap even though I use lube and back feed every 1/3 turn . I also have a set of Clarke taps which do seem to be more robust.
      I appreciate you get what you pay for and realise that the Burgen and probably Clarkte taps are made in China.
      So I then read up and hear about spiral taps, the advantage being they clear the swarf better.
      So, to me question, am I better getting a m2.5 spiral tap or std 4 flute tap for this job?
      Edited By petro1head on 01/05/2017 07:57:22
      #8695
      petro1head
        @petro1head
        #295740
          I don't have any spiral taps and can't remember the last time I broke a tap. Set of 3 standard Volkel ones from Rotagrip should do you OK
          Edited By JasonB on 01/05/2017 07:58:15
          #295742
          Anthony Knights
            @anthonyknights16741
            I've used a set of Clarke taps for 10 years and never broken one. If yours have 3 taps per size, are you using then in the right order?
            #295745
            John C
              @johnc47954
              Bucking the trend here, but… I have a set of spiral taps bought from Cromwell on special offer. Still not cheap though, but very good value for money and work very well indeed especially in blind holes.
              Lambton
                @lambton
                petrol1head,
                If you are regularly breaking taps you are probably using a too small tapping drill. I recommend that you buy the book Drills, Taps and Dies by Tubal Cain. He explains all about selecting appropriate tapping drills and include comprehensive table at the back. An excellent book for the price of one good quality HSS tap!
                #295751
                  Posted by Lambton on 01/05/2017 08:52:35:
                  petrol1head,
                  ^^^^^ +1 on all of this. Tubal Cain's Model Engineer's Handbook also has all his charts for correct drill sizes to get 85 per cent, or even 65 per cent, thread engagment, which still gives full strength threads but cuts WAAAAAY down on broken taps in these smaller sizes.
                  #295753
                  petro1head
                    @petro1head
                    I am using the taps in the correct order and I have bought specific drill to suit the tap. It's more likely that I was being ham fisted
                    #295754
                    Henry Artist
                      @henryartist43508
                      Breaking taps may be more down to technique rather than brand…
                      Using a slightly larger tapping drill can make a real difference e.g. for M2.5 I would use a 2.10mm – 2.15mm drill in preference to the recommended 2.05mm depending on the material. YMMV.
                      Using a lubricant like Trefolex can also help.
                      #295766
                      Chris Evans 6
                        @chrisevans6
                        Ensure the tap is started upright to the hole, go up say 0.1mm on tapping size drill and you should not break a tap. I always tap on the mill and bring a tapping guide down on to the tap when starting. Sometimes this is just a small threaded shank cutter held upside down in the collet/chuck to use the centre. I use the upside down cutter when I can't find the spring loaded guide I made 50 years ago. For taps with a centre in the end and not a point a simple pointed piece of silver steel will suffice. On bigger taps I hold them in the chuck and turn the first few threads in to the job by hand rotation of the machine. I've not broken a tap for 20 years but do always buy quality high speed steel taps.
                        #295768
                        KWIL
                          @kwil
                          Spiral taps every time for preference, they are a one-pass job, without the necessity to start taper, then 2nd and then plug/bottoming.
                          #295771
                            Where the job allows ( which the one in question does) I just drill the blind hole deeper than needed to get a good thread length that way you can tap a blind hole with just a taper tap so still a one pass job.
                            #295774
                            petro1head
                              @petro1head
                              Comparing the Clarke and Bergen taps the Clarke ones look noticably sharper.
                              I have bought a set of 2.5mm Volkel taps from Rotagrip for this job though and will buy a 2.1 drill as advised by Henry
                              #295776
                              John Haine
                                @johnhaine32865
                                At the Midlands exh. last year I bought a set of spiral taps plus tapping drills from Greenwood Tools, and they are excellent! On this basis, and also having a couple of other spiral taps, I thoroughly recommend them. I also now usually tap in the mill under power, setting the VFD to 5 or 10 Hz. One is only tapping for a few seconds so there's no downside to this. I drill the hole; replace the drill with the tap; bring down to the hole using the lever quill feed (as for drilling); hold the lever so the tap is just bearing on the job, switch on the spindle in forward so the tap cuts the thread, still holding the feed lever; stop the spindle when cut enough and reverse to back out the tap; all the time keeping pressure on the feed lever so the net axial force on the tap is zero. If it's a blind hole I just get the tap started; stop the mill, lock the quill, loosen the chuck; then raise the quill and complete the job by hand. So far no broken taps in dozens of holes.
                                Also I second the Tubal Cain book and technique. You almost never need full engagement, much better to use the minimum you can, it hardly affects the strength of the thread and actually since I got the book and started using his methods I have never broken a tap.
                                #295781
                                Anonymous
                                  Rule 1 – Buy decent HSS taps from professional suppliers
                                  Rule 2 – Drill the tapping hole for partial thread engagement, for M2.5 in steel I'd be drilling 2.2mm
                                  Four flute? I've just looked at a selection of my small taps (<6mm) and they are all 2 or 3 flute. I wouldn't expect to see a 4 flute tap much under 10mm. Four flutes simply doesn't give enough room for the swarf.
                                  Spiral point and spiral flute taps are intended for machine tapping. Spiral point are for through holes and push the swarf forwards. Spiral flute are for blind holes and push the swarf backwards, out of the hole. In a ductile material you will often get spirals of swarf exiting the hole. Despite being intended for machine tapping both SP and SF taps can be used by hand without a problem.
                                  I have a few spiral point taps but I tend to use spiral flute for my most common threads, blind or through hole, machine or hand. I'm with KWIL on this; you only need to buy one tap, they cut easier than hand taps, the swarf tends to get ejected rather than jamming and they cut to within a pitch or two of the bottom of a hole in one pass. I seem to end up tapping a lot of blind holes where drilling deeper is not an option due to design contraints.
                                  Here's the tap I will be using this afternoon, 3/4" UNF:
                                  This is for the pipe connections for an experimental heatsink. The pipe bore needs to be a minimum of 12mm, but the heatsink also needs to be as small as possible, so 1/2" BSP is out. Of the common threads UNF is the finest pitch in 3/4". I already have a set of 3/4" UNF hand taps but the hole isn't deep enough to allow them to be used. crying 2
                                  #295789
                                    The other thing is to make sure the tap goes in straight. I got on much better after making a tap-stand and/or holding the work and tap in the lathe. Small taps are delicate and the cheap ones (carbon steel?), are particularly brittle.
                                    I've not been able to find the product since, but at school I remember a stick of plastic or wax being pushed into the hole first. As the tap went in the stick was squeezed out like toothpaste taking the swarf with it. Anyone know what that was or am I dreaming again?
                                    Funny you should mention 'Bergen'. I bought a set of their small metric spanners last week; they're 'fit for purpose' but have a poor finish. I have a hobby-horse about the foolishness of blindly trusting Brand-name purchases so I did some research. It seems that the original 'Bergen' were a US company selling expensive tools. They ceased trading many years ago. The name is now being applied to a range of what I suspect to be re-badged generic economy tools.
                                    I have a motorcycling friend who has spent a fortune on Snap-On tooling, very nice. Every time I see him he tells me that they are worth it because they last for ever. I haven't had the heart to tell him that both my cheapo Japanese spanner sets are still going strong after 40 years. (It doesn't prove much because we're both moderate-use hobbyists, not professional mechanics.)
                                    Antony Powell
                                      @antonypowell28169
                                      Hi Perto1head
                                      from someone that uses taps everyday for work….
                                      As Andrew says – Rule 1 – Buy decent HSS taps from professional suppliers
                                      both Bergen and Clarke taps are cheap carbon steel and don't compare to decent HSS
                                      Spiral fluted taps clear any swarf far better than straight fluted ones.
                                      Hi Sillyoldduffer
                                      I vaguely remember a similar product – was it a wax crayon ?
                                      I Use spanners / sockets etc every day and snap on tools are far superior to cheaper options, they are more comfortable to hold for longer periods, usually fit better, wear less and are stronger than many other premium brands and of course the biggest thing is if you break it they give you a new one .
                                      Theses days Halfords ​are doing a nice professional range of tools with a similar guarantee but you need to show the receipt, I also find them good tools for the money and ideal for a newbie or someone wanting good tools at reasonable money.
                                      Tony
                                      Edited By Antony Powell on 01/05/2017 12:28:45
                                      #295806
                                      petro1head
                                        @petro1head
                                        Well I have assigned my Bergen set to the bin (well actually given to a pal) and have purchaced a Volkel set
                                        #295807
                                        Andrew Tinsley
                                          @andrewtinsley63637
                                          I have both carbon steel taps and HSS, I can't tell the difference in use and I have yet to wear out any carbon steel taps. For hobby use I don't think it matters as long as they are decent quality.
                                          Tubal Cain's tapping drill sizes are the way to go, Using the manufacturers chart's suggested hole size, is a recipe for breaking taps.
                                          Andrew.
                                          #295811
                                          Brian H
                                            @brianh50089
                                            When I first started work, after a period of being self employed, I bought a set of 1-10 BA carbon steel taps and dies as I just getting interested in model engineering and the inspection department that I worked in had a Boxford lathe.
                                            Now, 50 years on I still use the set and only 2 taps have had to be replaced due to wear.
                                            I think the previous comment about using the correct sized tapping drill and not aiming for 85% engagement is absolutely correct along with the use of lubricant.
                                            Brian
                                            #295814
                                            petro1head
                                              @petro1head
                                              So have I wasted my money now
                                              #295821
                                              Anonymous
                                                Posted by petro1head on 01/05/2017 13:57:59:
                                                Not necessarily. The key phrase is "decent quality". Fifty plus years ago commercial tap manufacturers made both carbon steel and HSS taps. Carbon steel taps would have been cut, HSS steel ones ground. I don't think any commercial tap manufacturer makes carbon steel taps now. So if you want good taps from a commercial manufacturer you need to go for HSS.
                                                #295827
                                                  Not at all – I learned a few things too. (Thanks chaps)
                                                  Don't be surprised to break small taps, it's not that unusual. How to remove a broken tap from the hole is a popular forum topic too!
                                                  Painful experience has taught me that a gallon of patience is needed for every teaspoon full of cutting fluid. I'm not a natural in the workshop and find that the problem is often me rather than the tool. I improve slowly with practice. I'd suggest starting with inexpensive new taps (provided they're sharp) on brass. M4 is big enough to take a bit of abuse: if you break one it's probably bad technique. My taps mostly come from Tracy Tools and have met my hobby requirements well.
                                                  It's useful to experiment with different sized holes. Unless it's critical I usually drill tap holes a tad bigger than recommended in the tables, e.g 3.5mm rather than 3.3 for M4. This weakens the fastening slightly, but reduces the strain on the tap enormously. A trick learned on this forum.
                                                  The metal being tapped makes a big difference too. Tapping M4 in a 3.5mm hole is brass is easy. Tapping M4 in a 3.2mm hole in steel is much harder. Aluminium is deceptively soft but the swarf tends to stay in the hole and jam the tap, snap! Copper is horrible – it tears.
                                                  Take care to remove swarf and always apply lashings of cutting fluid, CT90 works for me.
                                                  Edited By SillyOldDuffer on 01/05/2017 15:14:27
                                                  #295833
                                                  richardandtracy
                                                    @richardandtracy
                                                    I have used Bergen taps without problems in the past. Rarely use anything smaller than M6, and when I do, it'll be M4. I always drill M4 at 3.5mm and use cutting paste. So far (firmly touching my head as there's a fair bit of wood in there) I've not broken an M4 tap.
                                                    Will say I tend to get Bergen for some of the odder sizes I use, like 3/8 BS Cycle (26 tpi), as they are cheap enough for rarely used sizes to be viable and not break the bank.
                                                    Richard.
                                                    #295835
                                                      No, you will have a set of 3 good quality M2.5 taps that will cut well. Given that the hole you intend to use them for is to take a Torx screw for an insert I would not go larger than 2.1mm for the tapping drill as there is not much length to these screws and we tend to wind them in quite tight.
                                                      You will also be able to use them in situations where you cant assure there is support for the other end directly above the work which is where a taper tap will be easier to start true into the hole.
