Stirling engine
Stirling engine
Home › Forums › Beginners questions › Stirling engine
  • #243401
    Amanda Alderman
      @amandaalderman52575
      Would I be able to sell this working model that my Father made? If so what should I ask for it?
      #8171
      Amanda Alderman
        Rider Ericsson hot air pumping engine
        #243550
        Ian S C
          @iansc
          Amanda, I don't see any photo, one would help. I'm sure someone would love your Stirling Engine. Ian S C
          #243558
          Amanda Alderman
            #243559
            Amanda Alderman
              #243562
              Amanda Alderman
                Thank you for responding Ian. With a little help have added photos, sorry not correct aspect!
                The basic dimensions of this modle are: 17" high, 10.5" wide, wheel 9" diameter. Is this a quarter scale?
                Amanda.
                #243563
                  Its always a bit hard to put a price on an engine as most of us like to build the engine but there are collectors about too. The Camden one is a good size and this one looks to be well made, you could be looking at £1500 plus
                  Yes 3" to the foot is 1/4 scale
                  #243565
                  Amanda Alderman
                    OK, thanks Jason, that's interesting, and promising!!
                    I'm certain that it is well made, my Dad was quite a perfectionist!
                    Amanda
                    #243654
                    Ian S C
                      @iansc
                      Thanks Amanda, that's a beaut looking motor, Jason could well be right with his figures. Ian S C
                      #243729
                      Amanda Alderman
                        Thank you both very much for your comments and advice.
                        I will endevour to post on the "for sale" board and see what happens!!!
                        Amanda.
                        #243730
                        Amanda Alderman
                          Amanda.
                          #292042
                          Pat Bravery
                            @patbravery
                            Hello, I need some advice. I have started to build a small stirling engine and it requires a 16mm glass test tube, I have several but they are too long so the question is how do I shorten them, they are 'Pyrex' glass which is heat resistant. I have thought about a piece of string soaked in meths and lit then plunged into cold water, would this work? Thanks in advance, Pat
                            #292043
                            Andy Holdaway
                              @andyholdaway
                              Pat,
                              I've cut test tubes for a stirling engine by carefully mounting in the lathe chuck and cutting with a diamond disk in a Dremel. Run the lathe slowly and apply the disk to the cut mark and it will go through fairly quickly leaving a decent edge.
                              Andy
                              #292045
                              Ian S C
                                @iansc
                                I have a Stirling Engine friend in Belgium who, with his school class builds Stirling Engines each year (he's a school teacher), his method is to(gently) grip the tube in the lathe chuck, and use a Dremel with a diamond cut off wheel, run the lathe slowly, and drip water on the area being cut.
                                The last time I cut a test tube, I made a wooden V block to rotate the tube on, and scored the tube with a glasiers diamond glass cutter.
                                Ian S C
                                #292047
                                Curtis Rutter
                                  @curtisrutter61973
                                  There's lots of differing techniques on YouTube.
                                  #292049
                                  richardandtracy
                                    @richardandtracy
                                    That model is one of the 'Rider Erikson' type of Stirling engine. Came as a real shock to me that the 'Erikson' was the same Erikson who designed the 'Monitor' used in the US Civil war and had a loco in the Rainhill loco trials. Quite a stunningly versatile engineer.
                                    Richard.
                                    #292055
                                    Pat Bravery
                                      @patbravery
                                      Thank you all, I used the lathe with Dremel and the result is perfect. Thanks again, Pat
                                      #292171
                                      Ian S C
                                        @iansc
                                        Good work Pat, if you have any troubles with your motor,bring them along, and we'll try and sort them out.
                                        Ian S C
