Valve gear problem
Valve gear problem
Home › Forums › Locomotives › Valve gear problem
Viewing 3 posts - 1 through 3 (of 3 total)
  • #813860
    John Billard 1
      @johnbillard1
      I would greatly appreciate some advice.
      My project (since 2000 with interruptions) is building a 5″ Great Eastern Super Claud.  Basically my own design but with reference back to the Martin Evans version for various aspects.  The tender is completed in some detail and I have made the boiler which has been proof tested by our club inspector.
      As part of the design I have followed GER practice by putting the valves under the cylinders.  This has led to a direct drive valve gear, outside admission, with loco links. For the basic layout I followed the Martin Evans Jinty design with adaptions to suit the engine including the valve chest/valves which is Evans dimensioned.  The resulting valve gear design was verified by using the Hall S-1 program which gave good valve events and steam distribution on simulation.
      However on attempting to set the valves I have run into great difficulty in setting the eccentrics to produce any satisfactory result at both ends of the travel and in forward/reverse.  Clearly something has gone wrong and I am at a loss to go further.
      Can anyone help?  I will willingly make changes though I would regard the cylinder and crank axle as fixtures.
      I would like to have the engine running one day and time is not on my side!
      Best wishes
      John B
      #813866
      duncan webster 1
        @duncanwebster1
        John you have a pm
        #813869
        Charles Lamont
          @charleslamont71117
          To be able to offer help here on the forum, I think we are going to need drawings.
