Drummond oddities
Drummond oddities
Home Forums Beginners questions Drummond oddities
Viewing 25 posts - 1 through 25 (of 35 total)
  • #238103
    Martin Newbold
      @martinnewbold
      I found this on eBay and was curious as there was a spring on the main drive control does anyone know what this is for and what it does please?
      drummond od addition to switch
      This is a close up
      closeup of spring
      #8125
      Martin Newbold
        @martinnewbold
        a thread about peculiar additions to Drummond Lathes
        #238113
        Rainbows
          @rainbows
          I have never had a drummond but my guess is that when you press the lever left the feed activated and that latch mechanism falls over the lever locking it in the engaged position. Once the saddle reaches a certain point a metal bar that has since fallen off the saddle would then poke the top of the latch and release the lever so that the spring pulls it into the disengaged position. Would allow for accurate repeated cuts and reduce the risk of crashing the carriage.
          #238117
          bodge
            @bodge
            Yes home brewed auto knock off,…. auto disengage came as standard on M types
            Edited By bodge on 09/05/2016 21:34:35
            #238121
              You should post some pictures on the Drummond Yahoo group. for the record.
              #238124
              Muzzer
                @muzzer
                Have you seen this thread? Photos of the approved machine half way down, although the one in the thread has been extensively modified by the looks of it.
                #238137
                  There appears to be a pair of drilled and tapped holes added to the top of the cross slide for some sort of actuating rod to be attached to. Probably something like the below pic from another ebay ad. Must have been a popular mod in the day.
                  The one you posted looks like a pretty nice clean machine. Nice pile of changegears with it, which are probably worth as much as the lathe itself!
                  #238146
                  Martin Newbold
                    @martinnewbold
                    Yep I have one hopper but didn't have this adaption on mine your looks pretty much nicer mod to shut of feed
                    #238153
                    Martin Newbold
                      @martinnewbold
                      For some reason I cant login on Yahoo so gave up with that 😐
                      Yes Muzzer my B type has had a lot of changes at least 50 years ago it came like it to me in that link post you posted and had been in storage about 50 years before i got it . It has a different slide and a different gear banjo which looks much stronger.
                      #238205
                      bodge
                        @bodge
                        Well your not alone , you me and a few others have had trouble with the yahpoo site !!
                        The original gear banjo dosnt suffer from any strength problems, its the boss cast integral with the lathe bed that the banjo fits onto that`s the  weak point, the outside edge of the boss breaks away . This happens because of either, [a] the locking bolt is not withdrawn far enough to clear the grove machined in the boss, so it get tap to help it along !! or [b] or original bolt which has a plain bit on the end that fits in the grove gets lost so whatever bolt fits gets used, but no plain end then gets over tightened which causes outer edge of boss to break away!! take look at the post Drummond pre-B type lathe ( 1/4 scale ) if you down load first pic you can then enlarge it and see broken boss the banjo fits on……………..b
                        The nice thing about the one in Hoppers pic is its not been over chucked, a 3 inch chuck is about the head stock bearings limit.
                        Edited By bodge on 10/05/2016 16:00:24
                        Edited By bodge on 10/05/2016 16:13:54
                        #238567
                        Martin Newbold
                          @martinnewbold
                          Me to tried to get on Yahoo , but didn't work so gave up ;-|
                          My one has big bosses either side which strengthens the fitment . This was done 50 years ago:
                          #238618
                          Ady1
                            @ady1
                            It may depend upon the internet browser you use, (which someone mentioned before somewhere on here)
                            #240086
                            Martin Newbold
                              @martinnewbold
                              yep its not good Ady gave up too does anyone have some more modz to share please?
                              #241307
                              Martin Newbold
                                @martinnewbold
                                Modz to my gears on my Drummond B type to cover them from ML4 covers . I had no idea what and how they fitted but had a bash. Dont have the witworth bolts yet hence why bolt is sticking out as they are on order.
                                New bracket for ML4 covers
                                #241508
                                bodge
                                  @bodge
                                  " does anyone have some more modz to share please? "
                                  Safety type chuck key ?…………..b.
                                  #241530
                                  Martin Newbold
                                    @martinnewbold
                                    hope so to bodge. No motor attached to mine as still awaiting to hear what the idiots who sold it do before i take them to court. So chuck key is safe its how i rotate chuck to keep it lubricated.
                                    #243914
                                    Martin Newbold
                                      @martinnewbold
                                      Well think one of you is going to be a lucky person look what i found **LINK**
                                      #243919
                                      Ady1
                                        @ady1
                                        That guy is selling what looks like a good M series longbed, offering postage too, countershaft and various bits 'n bobs etc, a rare chance at a very decent Drummond starter kit.
                                        #244076
                                          Posted by Martin Newbold on 23/06/2016 16:31:22:
                                          Not me, at 91 Pounds and four days remaining. Yikes! It would be nice to have but not that nice.
                                          #244077
                                            Posted by Ady1 on 23/06/2016 18:20:44:
                                            Yes, very nice pile of accessories etc and the lathe looks in well kept shape too. I can't believe how cheap these old beauties sell for in the UK. If only the shipping were not so prohibitive to the colonies.
                                            #261720
                                            Martin Newbold
                                              @martinnewbold
                                              Have been working on a conversion for a ML10 tail-stock providing an MT2 dead centre
                                              http://www.model-engineer.co.uk/forums/postings.asp?th=119865
                                              Edited By Martin Newbold on 18/10/2016 15:03:18
                                              #262106
                                              Ady1
                                                @ady1
                                                A Drummond metal muncher from 1914, wow
                                                The countershaft system looks "unusual" to this hobbyist (in other words I don't understand it but I'm sure it works)
                                                A few possibly original bits from a long time ago too, a nice new motor to run it and a 1 inch spindle bore (drool drool drool)
                                                Edited By Ady1 on 20/10/2016 21:27:06
                                                #262111
                                                  Posted by Ady1 on 20/10/2016 21:23:33:
                                                  The countershaft system looks "unusual" …
                                                  Probably wise not to wear a kilt when using that ^^^
                                                  Nobby
                                                    @nobby
                                                    Hi I added a 3rd arm on my Drummond to get a slower feed Click on my photos  to see the other parts added Nobby
                                                    arm
                                                    Edited By Nobby on 20/10/2016 22:26:50
                                                    #262175
                                                    Martin Newbold
                                                      @martinnewbold
                                                      Nice work Nobby, have one spare too I had to take it of to fit the tumbler I have.
                                                      Fixed my ML10 mount onto the bottom Drummond saddle not very elegant yet but suffices to take up the distance giving me a new amount .
                                                      Bolted down top part for a proper test in difernece of height
                                                      Now have a smaller amount to remove
                                                      New reading
