An alternative response to the 'We don't have giant insects' debate:
We have never had huge insects because the weight goes up with the volume of the insect but the lift depends on the area of the wings. In the distant (fossil) past, there were are few bigger than modern insects, but nothing as big as an eagle or a vulture, because their lungs and feathers are more efficient. It is surmised that the big fossils were from a period when oxygen levels were higher, but this runs contra to the science of fire which says that with more % of O2 wildfires would be much more prevalent.
While the rule works against the production of power from steam (or petrol etc) it works in favour of model gliders. The smaller the plane, the easier it is to make it fly, as the weight goes down faster than the lift as you go smaller. You can even make a solid oak glider fly if it is small enough (but watch out or the cat will eat it).
There are other effects involved in the broad 'can't scale nature' debate – especially surface tension and related effects.
Regards, Tim
