Hi,
This is my first post on here so please forgive me if it's the wrong place to post this. It seemed a logical place given my knowledge of lathes – yes, you guessed it, a newbie!
Anyway, I've been after a lathe for a while but have often been priced out on places like Ebay, GumTree, etc. And I could never afford anything from more knowledgeable outlets. I always thought I'd need to work on anything I get and that proved to be the case.
I found on Ebay what was described as a Perfecto model maker lathe. It works and turns, but does need a lot of restoration work. The motor is filthy with wood dust (previous owner was into woodworking so this became surplus to his requirements), but it seems OK. It does need a proper switch… the motor is wired to a plug, and that's it!
Reading up, I found out that they're similar to Myford ML2/3/4. However, rust, dirt, and general neglect aside, the one thing that puzzles me is the fact that every search I've done online for information shows that Perfectos, and indeed the similar Myford's, all have leadscrews for power feeds. This one has no leadscrew/power feed at all, at least that my novice eyes can determine. It does seem to have the castings to take one, except they haven't been drilled out. It also seems to have superfluous gearing underneath the headstock which would, I suspect, be used for the leadscrew had it been fitted. Also, everything I've seen shows the Perfecto sticker on the headstock with a serial number… I haven't found serial number at all, yet, let alone where you would expect to find one.
I have many other questions about it, including an interesting lever at the side of the chuck that seems to engage another gear, and various things that I think may be missing.
But my main question is, does anyone know exactly what this lathe is so I can find spares if needed, or just simply know what I have?
By the way, forgive the clamps in the photos holding the lathe up. The motor and pulleys pull it over to one side, so I used the clamps to keep it upright until I get a bench for it.There are more photos in the album "Perfecto (??) Lathe" on my profile.
Many thanks for any help anyone can give me.
Cheers,
Iain
