brake material
brake material
Home › Forums › Beginners questions › brake material
  • #150698
    nigel jones 5
      @nigeljones5
      Is there any reason not to make my invicta parking breaks from brass – acting on a steel wheel?
      #7126
      nigel jones 5
        @nigeljones5
        #150703
        Ian Welford
          @ianwelford58739
          could you not use the mini brake pads from Halfords or cycle shops hidden in the brass surface? Saving wear and tare?
          You going to Harrogate then ?
          Regards Ian
          #150741
          Tim Stevens
            @timstevens64731
            One problem you might find is that the contact surfaces will not always be dry – they will be contaminated by water or oil. Either way, the friction will all but disappear, and your brakes will fail.
            What is wrong with conventional brake lining material, which can be rivetted or bonded to the shoe (or plate, etc)?
            Cheers, Tim
            #150750
            Roderick Jenkins
              @roderickjenkins93242
              Copper alloys tend to be used as bearings with steel because of the low friction between the two metals. In general, dissimilar metals provide low friction and similar metals high friction – so steel might be a good choice for the brake on your steel wheel. This sort of situation wasn't used in full size because you want the brake material to wear at a higher rate than the wheel so that that the pads are easily replaced consumables. My guess is that the original Invicta (1:1 scale) would have had wooden brakes. Tufnol would probably make a reasonable scale alternative.
              HTH
              Rod
              #150764
              Clive Hartland
                @clivehartland94829
                Ah, the smell of hot Tufnol. Applied heavily I wonder if they would catch fire? If its for parking I would use the hard bicycle type of brake block, easily shaped and fit into a holder.
                #150776
                nigel jones 5
                  @nigeljones5
                  Thanks all
                  Ian – Most likely will be going
