Slitting saw thickness
Home Forums Beginners questions Slitting saw thickness
  • #78672
    Skarven
      @skarven
      Hi,
      I have a slitting saw 125x27x2 72T and I feel that for cutting purposes, it could be thinner. At 600 rpm and lots of oil it cuts 25mm aluminum beautifully, with an almost polished surface. The sound though is frightening, with hearing protection, even in the next room a must.
      Is there an optimum thickness for slitting saws? At CTC Tools they sell the 125mm with thickness from 0.8mm to 6mm.
      #5773
      Skarven
        @skarven
        #78673
          I think its more the optimum speed thats your problem, sounds too fast to me, I usually use 3″ to 4″ ones at about 200rpm.
          J
          #78674
          Skarven
            @skarven
            I tried 75, 180 and 280, but they all gave a lot of vibration. This might be a resonance problem. I have ordered two VFD’s, one for my lathe, and one for the mill, mostly because I want to make lower speeds possible, but maybe they can be used to tune away some vibrations?
            Is there a problem with a thickness of only 0.8mm? Will it break easily?
            #78681
            Hugh Gilhespie
              @hughgilhespie56163
              Hi Skarven
              This link has some useful information on slitting saws on page 13.
              Regards, Hugh
              #78695
              Anonymous
                The problem is unlikely to be resonance, as it occurs at a series of unrelated frequencies.
                Running at 600rpm is prehaps a little fast for aluminium; 400rpm may be better. There is no way the slitting saw should be making the kind of noise you describe. I suspect the problem may be too low a feedrate. What feedrate are you using?
                Best Regards,
                #78697
                  The VFD will help, I find that if I’m doing something that starts to resonate then slightly modulating (fancy name for turning up and down) the speed knob you can stop it before it gets too bad.
                  Nothing wrong with using a thinner cutter but there is a slight risk of them going astray.
                  I have heard of people using TCT saw blades made for cordless circular saws to cut alloy on the mill, the advantage of the tips is there is more clearance behind and they had quite a narrow kerf about 1.4mm.
                  J
                  #78714
                  Skarven
                    @skarven
                    Hi,
                    Thanks for the link Hugh, There was a lot of info there.
                    Martindale gives a rpm of 950 for a 4″ saw in aluminum, this should be app. 760 for a 5″ saw.
                    Andrew, I think You are right. The feed was very slow. In fact it was as slow as I could get it, about 0.5mm/s or 30mm/minute. This is 30mm / (72×600) = 0.0007 mm/tooth.
                    Martindale recommends 0.0002″ – 0.002 per tooth or 0.005 – 0.05mm / tooth.
                    I will try a few more cuts with a higher feed rate and report back the result..
                    I hope my saw has survived the 400mm cut 25mm thickness at snail pace
                    JasonB, I have also noticed that sometimes both decreasing and increasing the speed will avoid chatter, so I look forward to test the VFD’s on both the mill and the lathe.
                    #78723
                    Steve Withnell
                      @stevewithnell34426
                      I’m not an expert on using slitting saws but…I’ve not used a saw above 100m x 1.5mm and would run below 400rpm. Also I only take light cuts, on a 3 inch saw with 60ish teeth I’ve been doing 0.5mm per pass in aluminium and just keeping up the feed rate so the saw is always cutting. I use parafin as a cutting fluid to stop the ally sticking to the teeth. It all starts getting unhappy when I get beyond a 1mm deep cut and I’m 10mm or more into the workpiece. I also cut by pushing the work into the oncoming tooth, rather than pushing into the going away tooth, if that makes sense. (a la climb milling)
                      I use slitting saws only where I need a precision slot (say making collets, or a new butterfly bar for a carburettor), or maybe to part a component cleanly into two (eccentric straps for steam engines). Everything else is a hacksaw (or angle grinder with a thin cutting disc) as I don’t have a bandsaw.
                      I also don’t think you need loads of tech to get a slitting saw to work well. I only have a limited number of speed choices on my round column chinese mill, but it’s perfectly adequate.
                      #78724
                      Steve Withnell
                        @stevewithnell34426
                        #78727
                        Skarven
                          @skarven
                          Higher feed rate did the trick. 125x2x27 72T, 600 rpm and a feed-rate of 4mm/s or 240mm / minute. No vibration, almost no sound, just a healthy sawing one.
                          I had my fingers on all three stop buttons while cutting , so I took a picture after the cut and after resetting the X-axis for a new cut. I’m making 5 holders for a BXA QCTP so there are 3 more cuts to do. This really worked!
                          Thank you for all help!
                          #78732
                          Skarven
                            @skarven
                            Finnished cutting of dove-tailed blocks for BXA QCTP.
                            Each cut was about 10 seconds, although the setting up took much longer!
                            #78754
                            Sub Mandrel
                              @submandrel
                              What grade of alloy are you using Skarven?
                              I want to make a QCTP one day and chopping up alloy seems much more appealing than working through a few feet of mild steel.
                              Skarven
                                @skarven
                                Hi Neil,
                                I have 3 plates 370mm square and 25.4mm (1″) thick. They are marked “ALLA PLUS PLATE” and “P1115”. From what I can find out, the 1115 means that it is essentially pure aluminum. This is what I had from the scrapyard, so that’s why I’m using it.
                                If you make holders for AXA or BXA, the dimension for the dovetail is very critical. Even a cut of 0.02mm makes a real difference to the fit.
                                #78778
                                ady
                                  @ady
                                  I’ve found that cutting discs are far less scary than slitting saws.
                                  Stiffness for the disc and the work, a decent speed and a careful feed rate seem to be pretty essential to a decent job.
                                  Heat can be a major issue, especially aluminium, because the slitting saw gap can close as the aluminium heats up.
                                  There are various sources for cutting discs.
                                  Edited By ady on 28/11/2011 07:17:31
                                  #78788
                                  Ian S C
                                    @iansc
                                    I find the best aluminium alloy to work with in places where strength is required, and ease of working is 7075 T651 tooling plate, the place I get it from say in their ads that its “strong as steel”, also the sell scrap bit at a reasonable price, its definitly harder, and srtonger than ordenary extruded bar. Ian S C
                                    #78789
                                    John Stevenson 1
                                      @johnstevenson1
                                      Posted by ady on 28/11/2011 07:14:16:
                                      Care to link to what cutting disks are suitable for aluminium ?
                                      John S.
                                      #78792
                                      Gordon W
                                        @gordonw
                                        I’ve found that stone cutting discs work better on ally, and on copper. Found out by accident when cutting up scrap. Please note I am not recommending this! just mentioned it.
                                        #78797
                                        ady
                                          @ady
                                          Sorry. I just use what I’ve got. No names to name.
                                          Fleabay specials, extra thin, can be used on stainless.
                                          You’ve GOT to mount stuff properly, both the cutting disc and the workpiece.
                                          Those hand held things are a dangerous joke.
                                          Edited By ady on 28/11/2011 13:05:48
                                          #78799
                                          Billy Mills
                                            @billymills
                                            Ady , you might like to read this:-Grinding Aluminium. As far as I know most workshops go the same way as MIT and ban aluminium grinding- too many accidents.
                                            With a very thin cutting disk you can still get the melt-stick-shatter process which does not help at all.
                                            Billy.
                                            #78800
                                            John Stevenson 1
                                              @johnstevenson1
                                              From the bit of experience I have had with grinding aluminium you might as well use a hatchet, the finish and accuracy is far better.
                                              John S.
                                              #78828
                                              Nicholas Farr
                                                @nicholasfarr14254
                                                Hi, cutting and grinding discs specially suited for aluminium are available, below is a link to one source of cutting discs for use on aluminiun.
                                                http://www.buckandhickman.com/find/category-is-AB+Abrasives/category-is-AB03+Discs/category-is-AB0302+Cutting/DiameterENCODESTART44ENCODEEND+disc_mm-is-115/Bore+size_mm-is-22/product-is-068441
                                                And for grinding aluminium.
                                                Regards Nick.
                                                Edited By Nicholas Farr on 28/11/2011 22:10:00
                                                #78853
                                                alan frost
                                                  @alanfrost17805
                                                  Thanks for link,Nick. Evry day is a schoolday. Otherwise concur with JS provided a finishing hatchet is used NOT the roughing hatchet used for remodelling H & S inspectors..
                                                  #78854
                                                  Skarven
                                                    @skarven
                                                    After I got the feedrate right, thank you Andrew, I now feed 4mm/second and cut 370mm 25mm thick Aluminum in 90 secoonds, with a saw 125x2x27mm 72T at 600rpm, I see no reason to use a cutting disk for this kind of task. The finnish is really good. As long as I can put it on the mill table, I’m OK. If it’s too long for that, I’ll guess I will get a Aluminum cutting disk for the angle grinder.
                                                    I think cutting oil is a must though. I’m using rapeseed oil with no additives myself.
                                                    #78865
                                                    Sub Mandrel
                                                      @submandrel
                                                      You get a far better finish with extra virgin olive oil.
