Reply To: Confused ….Advice needed rotary table vs dividing head
Home Forums Beginners questions Confused ….Advice needed rotary table vs dividing head Reply To: Confused ….Advice needed rotary table vs dividing head
#527208
    I'll have a go at the differences! Feel free to put the mistakes right.
    Rotary tables are mounted horizontally, and most can also be mounted vertically. In both cases only at 90° to the mill table. A Dividing Head is always vertical, but can be tilted through 90°.
    Dividing heads are always fitted with 'indexing plates' (holed wheels and clock hands), allowing a wide range of angles to be turned. The indexing mechanism can do intermediate angles. Rotary tables can be fitted with indexing plates as an accessory, but usually the number of angles supported is limited compared to a dividing head. (A generalisation. And, because rotary tables do all common angles, the limitation may not matter.)
    Dividing heads are likely to be more accurately made and expensive than a rotary table. Extra accuracy costs money.
    Rotary tables are more convenient for general work because most jobs are mounted at 90° or 180° relative to the milling table. Possibly more robust than a dividing head for rough work. When close accuracy isn't needed, jobs can be spun rapidly by the rotary table without cranking the handle – a time saver. When accuracy is needed the handle and worm are engaged. Usually there's a vernier scale sufficiently accurate for most work. The handle is also relatively fast because most simple angles can be produced with it. For example, easy to crank from 0, 60, 120, 180, 240, 300, 0 to cut a hexagon head. Unfortunately not all angles are 'simple'!
    Indexing plates are useful for awkward angles. Cutting a 19 toothed gear requires 19 steps of 18.9474°, which is the hard to remember sequence 37.89, 56.84, 75.78, 94.74, 113.68, 132.63° etc. The Index plate and clock hand mechanism remove the need for the operator to track the sequence but they are still a pain to use in my opinion!
    Indexing plates are so awkward that driving a Rotary Table with a stepper motor and microcontroller is popular. You simply tell the controller how many divisions are needed, press 'Go', and the computer does the rest. Apart from reducing brain strain and automating a tedious task, the computer eliminates most mistakes. Computers don't get sums wrong, have excellent memories, and are hard to distract! Also, a computer and stepper motor will do a good job of angles too complicated for the Indexing plates.
    Generalising again, I suggest most people, most of the time, only need a rotary table. I see Dividing Heads as specialist tools and have never felt the need for one. For the same reason I drive an ordinary small car rather than a Land Rover. The closest I get to off-road driving is a supermarket car park! You might live on a farm…
    Unless there's a specific reason for needing a Dividing Head, I wouldn't spend money on one. My rotary table is used a lot, in contrast a Dividing Head is only 'nice to have'.
    Edited By SillyOldDuffer on 14/02/2021 15:56:21
