Aluminium on Brass Wheels
Home Forums Clocks and Scientific Instruments Aluminium on Brass Wheels
  • #481490
    Patrick Rundle 1
      @patrickrundle1
      I have been plagued with a problem for some time and unable to find a solution.
      I have cut some brass wheels using an aluminium backing disk. On some of the wheels aluminium is transferred onto the brass during the cutting process.
      I have yet to find a way of dissolving aluminium and not the brass – the best so far is Drain Cleaner which bubbles for some time, doesn't seem to attack the brass, but does not remove all the aluminium.
      Can anyone suggest a solution for this problem?
      Pat
      #3883
      Patrick Rundle 1
        @patrickrundle1
        Aluminium deposit on brass wheels
        #481495
        Andrew Tinsley
          @andrewtinsley63637
          An easy solution is to dunk the wheel in an alkali solution. Sodium hydroxide solution is probably the best , but any alkali will do. Sodium carbonate solution (washing soda) or sodium bicarbonate solution should do the job, but more slowly.
          Andrew.
          #481501
          Patrick Rundle 1
            @patrickrundle1
            Thanks for that.
            I've checked the contents of the HG liquid drain unblocker I used and the active ingredient is sodium hydroxide.
            As I said it bubbles for some time so is probably dissolving most of the aluminium.
            The surface left when bubbling stops still looks aluminium coloured rather than brass coloured.
            Pat
