Caprotti Valve Gear
Caprotti Valve Gear
Home Forums General Questions Caprotti Valve Gear
  • #604156
    Chris Crew
      @chriscrew66644
      Having just admired Duke of Gloucester as built by The Steam Workshop on YouTube, I have suddenly become intrigued by the operation of Caprotti valve gear. I have viewed the animations by Graham Shirley but, to this bear of little brain at least, without commentary it is difficult to grasp the details of its operation except to appreciate the overall concept of a camshaft operating poppet valves. Achieving reversal and cut-off is, at this moment, a total mystery to me.
      I would really like to try to understand more about this valve gear simply as a matter of interest because I certainly don't possess the level of skill required to build anything of this complexity and detail. Therefore, may I enquire if there any books available that may explain its operation in words of one syllable or where I may find more information about this fascinating mechanism.
      #28759
      Chris Crew
        @chriscrew66644
        Any books?
        #604160
        Clive Brown 1
          @clivebrown1
          Hi Chris, I've got a vague memory that Martin Evans gave some explanation of Caprotti gear in his book "Model Locomotive Valve Gears". Might be wrong though, my copy went missing some time ago.
          #604161
          Dennis R
            @dennisr
            #604169
            Chris Crew
              @chriscrew66644
              Dennis, thank you for the document link. I am beginning to get my head around the mechanism but not quite there yet, especially visualising the inlet valve's double lever and cam follower arrangement. It is certainly a very clever innovation of rotating two cams against each other to vary the arc of the lobe dwell. I will read the document's explanations again and try to relate it to the animations on YouTube.
