Like Jim I test run all my engines without gaskets, piston rings/packing or gland packing. Once happy with how they run they get painted and if I feel like sealing surfaces which I don't always then I tend to use a liquid silicon gasket as it does not add any noticeable thickness to the joints and throw the alignment out. You could get away with DIY silicon or a small tube of auto gasket from the likes of Halfords or e-bay.
Although there is nothing to really leak out when air running you can find a bit of oil works it's way out of any slight gaps after a while.
