When I was in Tech College during my apprentice training, we used copper sulphate solution as a marking fluid. It left a brown (metallic copper I presume) long lasting, non flaking deposit on the surface of the component. It also was a matt surface which showed up thin marking lines well. However, the thought of trying to buy copper sulphate crystals now is probably slightly more difficult than sourcing TNT. I can’t remember how we removed it though (I was too preoccupied with the girls from Hairdressing 1 to concentrate on our tweedy lecturer).
I think that this only works with steel though. However I find that permanent markers here in the UK provide a non flaking, long lasting coating. In fact I find the stuff difficult to remove and have to resort to acetone as a solvent. The marker is clean, easy to control and doesn’t rub off or stain fingers and keeps well. I have used mine for quite a time now without problem.
Dear Sid H. you’re really lucky to be able to get any engineering equipment or component locally. I called in in my local engineering supplier today to find out that they stock very few items now as there is so little of the engineering industry left in this town which was once world famous for it’s engineering prowess and products. They now mostly sell builders and diy tools. Sad but true.
