Kennet Tool and Cutter Grinder
Home › Forums › Workshop Tools and Tooling › Kennet Tool and Cutter Grinder
  • #301440
    Stewart Hart
      @stewarthart90345
      Our club has been donated a Kennet Tool and Cutter Grinder like this http://www.lathes.co.uk/kennett/ its complete with all the bells and whistles except for the belt which is no problem and the grinder wheels. So the ? is does any one know the correct size of wheels for the grinder and a supplier.
      Cheers
      Stew
      #18540
      Stewart Hart
        @stewarthart90345
        #301450
        John Baguley
          @johnbaguley78655
          Hi Stew,
          I bought the complete kit from MES and the wheels came with it. I can measure them up if it would help.
          Stewart Hart
            @stewarthart90345
            Hi John
            That would be a great help, thanks.
            I've read through your build for this grinder:- great work
            The electric motor is rated at 2800 rpm as recommended, the pullies look to be 2:1 giving a wheel rpm of 5600 could you check what the ratio is of your pullies are.
            Stew
            #301891
            John Baguley
              @johnbaguley78655
              Hi Stew,
              Sorry for the late reply.
              The wheels that came with the kit are:
              1 off 100mm x 40mm straight cup Green grit – code number GC80-K42
              1 off 100mm x 40mm straight cup white aluminium oxide
              1 off 75mm x 10mm plain disc white aluminium oxide
              1 off 50mm x 25mm taper cup white aluminium oxide
              2 off 80mm dish white aluminium oxide
              The wheels are all 12.7mm bore and 80 grit and labelled Consort. The white whels are all coded WA80-JV1.
              The motor that I used was one I had to hand and is 1440rpm. The small pulley is approx. 1.5" diameter and the large approx 5.2" diameter giving a ratio of approx. 3.5. This will give a spindle speed of approx. 5000rpm.
              Hope that helps,
              Edited By John Baguley on 10/06/2017 11:23:18
              #302034
              Stewart Hart
                @stewarthart90345
                Hi John
                Thanks for the information I'll put it to good use.
                Cheers
                Stew
