I have an Axminster bandsaw, bought secondhand but not done a lot so not worn out. Im using blades M42 Bi metallic blades 10-14 vary pitch from Tuff Saws.
Up to now its performed faultlessly, then yesterday the blade that was in suddenly jumped off the wheels while cutting some 16mm mild steel round. I put it back on and two cuts later it snapped.
Its been in a while, so although it still looked in good nick, no teeth missing etc i thought fair enough, no drama, stick a new blade in. only had one more cut to make.
Second cut today on some 40mm EN8 round and a quarter of the way through the new blade snapped. I only had a very light feed on (saw is hydraulic downfeed) was stood at the lathe and just heard the ping as it let go…..bugger!
Just ordered 4 new blades, but at £17 a pop I'm reluctant to kill another new blade.
Could it be the tension that is too high ? or something else……Thoughts on a postcard please.
