Cheap 3 in 1 tig welder – any one used one?
Home › Forums › Workshop Tools and Tooling › Cheap 3 in 1 tig welder – any one used one?
Viewing 25 posts - 1 through 25 (of 129 total)
  • #270540
    Ajohnw
      @ajohnw51620
      Xmas is coming and I'm being asked about presents. Initial thoughts were tig gear for my inverter but while looking around I noticed these.
      Anyone bought and or used one? I'm not sure how the cutting aspect works as have never been near a plasma cutter. Some state air. No mention of what this one needs or maybe all are the same?
      The inverter with it is more powerful than I need and more powerful than the one I have but does go down to rather low currents which from playing with an industrial one I feel is important.
      Ajohnw
        @ajohnw51620
        #270551
        Paul Lousick
          @paullousick59116
          Hi John,
          I have a Rossi CT416 Tig/Stick/Plasma Cutter welder which is similar to the one in your link. (probably made in the same factory). The welder comes with a cheap TIG torch which is OK for hobby use. I have not used the TIG much because it requires pure Argon gas as a shield. (I also have a better quality MIG welder which uses Argon/CO2 gas for most of my welding. This gas burns away the tungsten tips in the TIG torch). Tungsten tips are not included with the welder and the welding mask provided was thrown in the bin.
          The stick welding option produces a better weld than my old transformer welder. It is also much lighter to carry. I have replaced the electrode holder with a better version but the one supplied does work.
          A compressed air supply is required for plasma cutting. The electric arc melts the metal and a jet of air blasts the molten metal away. There are lots of articles on Youtube https://www.youtube.com/watch?v=xT6MmwyLDKM
          with reviews and operation of this type of multi-function welder. It is a relatively cheap and useful addition to a home workshop. Not sure how it would stand up to heavy work.
          Paul.
          Edited By Paul Lousick on 07/12/2016 22:27:56
          #270560
          Nicholas Farr
            @nicholasfarr14254
            Hi John, not used one of this type, it probably does what it designed to do, but with only a 60% duty cycle, you should be able to small welding jobs OK, but you will not be able to do a lot of welding in one period, i.e. if you weld for six continuous minutes, you will have to allow it to cool for four minutes to prevent it from over heating. In my opinion the price reflects its value.
            Regards Nick.
            #270567
            charadam
              @charadam
              John,
              The spec says 22A input for MMA and 21A for TIG.
              These are presumably maximums, but just wanted to draw your attention.
              #270570
              Ajohnw
                @ajohnw51620
                Thanks Paul. I found a couple of video's. One put it over as a load of crap due to faults that prevented it from working at all. The one you linked to and another with a green case was pretty positive.
                I'm not too worried about the duty cycle. 6min in real terms is a lot of continuous welding. If it will run that long. In practice it may not flat out and may do better at lower currents.
                Think I am going to be tempted. One problem though. Not sure if I have enough pieces of scrap steel about to try all modes out. Sounds like it may be difficult to find out which bits go with which part. One of the video's showed it working via a foot switch but I wonder if the paddle on the torch is the part that actually controls the gas.
                I'm more of a stick welder really. My ancient hobby type transformer one hasn't been used for a long time and will have got wet and god knows what sitting in the garage. Due to that and as a need crops up now and again I bought an inverter a while ago but it's sat unused. I do need to do one job shortly that would be better done with tig to save chipping the residue off as it will be made of 10swg mesh. The main thing I found with stick welding is the need for a decent open circuit voltage to make it easier to strike the arc. I'd hope that the inverter types are some what better than many of the smaller transformer ones. The one I have isn't too bad. A number of people bought them but it's still tricky compared with the real thing.
                I'm tempted to do a Jason and fabricate a steam engine. Stick should be fine for that but tig should mean no chipping away at the slag. The cutting ability might be useful too.
                blushI think I still have a heavy extension lead some where that isn't on a reel. I melted the cable in the drum on one once because I didn't pull all of the lead out. That one hadn't a 100% rating either but wasn't being run flat out. I was using 1/16" electrodes. I still have loads of those in a box I bought a long time ago. Kept right next to the boiler.
                Martin W
                  @martinw
                  Item listed as being in Germany but seller is registered in China and been selling since 2011.
                  We had plasma cutters in the workshop and they were very impressive, alright they were dedicated expensive units, but they cut through metals with surprising ease and had minimum cut width plus only a small area of local heating to the metal either side of the cut and quite a smooth cut. One fired the plasma arc up as soon as the trigger was pressed, quite impressive but somewhat risky in careless hands, but the other would only fire up when the head was in contact or very close to the work piece, I believe it had some sort of RF sensor that controlled the system.
                  Martin W
                  #270599
                    Have you considered MIG? Less skill required compared to TIG (even I can do it – sort of!)
                    #270600
                    Ajohnw
                      @ajohnw51620
                      The currents should be peak not rms. From amazon questions people are running them on ordinary 3 pin plugs but I could switch to a 25amp plug and socket. I haven't worked the figures out but they quote the efficiency. Taking cut for instance 30amps at say 100v is 3kw 80% efficiency would up that and that could be a problem. I do know however that when an charger for EV's was designed to draw exactly 13 amp RMS the only plugs and sockets that would take it for extended periods were MK's. If they have changed I still have fine examples of Brit engineering on other things that don't need it. I'd have been happy with 80 amps on tig and stick. No idea what cutting needs but it seems it will cut 8mm.
                      I did notice that the company address is in China and item in Germany, or should be. Some of the sellers do have EU warehouses. Not sure how they arrange for this to work. Some don't and an email arrives saying no stock and etc and jam tomorrow with a longer delivery time. Just have to wait and see but I don't think they could make the delivery time they quote directly from China and I picked a listing that definitely showed stock. £199 including postage. As the bottom of the listing mentions tax being the buyers problem if shipped from China I added a note to the paypal payment – I wont pay tax etc. One thing for sure if it has to go back I wont pay the shipping costs. It's buy it now so ebay will look after that.
                      frownIf I look at the listing again I might find that all of them have mysteriously been sold. That's what happened last time I tried to buy something listed in the same way. It took a while to get a refund. Another was in the EU. It arrived on time but proved unsuitable. I was refunded eventually and they didn't collect the item so it was sold some months later.
                      old Al
                        @oldal
                        If you want a TIG outfit, spend a little more and get one with an impulse start. Scratch start ones are not good. TIG is an art, but, with a bit (lot) of practice, you can get some really good results. Give 'Welders Warehouse' a ring.(on the internet somewhere). they have been very helfull to me.
                        I junked my mig for doing welding on models and the other thing i did was junk the non refillable gas bottles.Check the availability of gas in your area.
                        Cant do without my tig now.
                        Best of luck
                        #270637
                        Ajohnw
                          @ajohnw51620
                          I've already ordered it Al. If I can cope with my transformer stick welder 55v to strike should be like being in heaven on stick anyway.
                          Bit of a problem. How do I know what to buy in terms of bits and pieces for the torches. When I used TIG at work a long time ago I'm pretty sure that it used plain tungsten electrodes but then there are collets etc of different sizes and no idea of what will fit. Plus the parts for the cutting torch look to be completely different. I assume both fit the torch that is supplied with it.
                          As mentioned it doesn't seem to come with any tig electrodes so wondering what to order. It looks like there are some collets and some cutting torch parts but ???
                          John Stevenson 1
                            @johnstevenson1
                            You need to ask yourself
                            "Is it fit for purpose ? "
                            Or is it
                            " Fit for purse ? "
                            #270649
                              Or if you gorge yourself on dolphin blubber, ask yourself, "is it fat for porpoise?"
                              I'll get my coat…
                              #270666
                              Simon Williams 3
                                @simonwilliams3
                                I had one of these a while ago I bought out of curiosity to try plasma cutting. I thought it was the vicar's underwear until it got nicked. I bought a much fancier replacement so I could weld alluminium. and a dedicated plasma cutter, but for the money I think this is a brilliant idea for a Christmas present. Enjoy! Simon
                                #270670
                                Ajohnw
                                  @ajohnw51620
                                  Posted by John Stevenson on 08/12/2016 14:27:05:
                                  Or is it
                                  " Fit for purse ? "
                                  As it's unlikely to be used much – fit for both providing it works and sparks come out of the end.
                                  I like the end of the mini review on youtube that Paul posted. Fit for DIY. I have all sorts of kit kicking about ranging from the cheapest to what might be called pro stuff. Much depends how much work it will have to do and how well it does it. Often there is no way of knowing if anything is any good without buying and trying. Other than this
                                  They might just have got it right by now but I will look at the leads to see if they need help.
                                  Ajohnw
                                    @ajohnw51620
                                    Here's one cutting. There are a number of video's about some on problems
                                    Seems to be more on the 416 than 316 which I assume is a more powerful version.
                                    Ajohnw
                                      @ajohnw51620
                                      I just had the tracking info arrive – on route from Hamburg. Makes a change because I wondered if it was one of those that mysteriously sell out and an email arrives saying they will ship one from China but I wont be paying tax and sorry etc.
                                      Ajohnw
                                        @ajohnw51620
                                        I'm back and it's arrived. No signs of the problems mentioned in the video. Wires look well attached to the torch and they don't look too bad generally. In fact the lot looks pretty neat really – how well it works is TBD and I haven't looked inside it yet or powered it up.
                                        The gas connections are all tapered ones with "serrations". I thought they might be rigid plastic pipe push fit ones. I'll need to buy a quick fit type to connect my compressor.
                                        The rating plate reckons it's 100% rated at 93 amps and the effective current draw flat out I assume at 120 amps is 13 amps equivalent. So about as much as can be put on a 13 amp plug really so in that respect just what I wanted.
                                        It mentions earthing the unit via a screw type terminal on the case. Can't get my head round that unless it's for rf emissions or doing car body work. Think I saw >= 2.5 mm^2 mentioned.
                                        I wont be running argon though it willingly unless I can fit a flow gauge to it some how. I had wondered about using the regulator that comes with it that I assume is primarily for cutting but max pressure is 10bar. I assume that is the input. The disposable bottles run at 60 odd and the refillable ones at 200 bar. I'm not sure if the simple regulators that screw onto the disposable bottles really regulate or are just flow restrictors. Anyone know ?
                                        There are plenty of regulators with flow guages about but that leaves the problem of connecting a disposable bottle to one. There are also 1/4" ntp flow gauges about. I don't really want to fork out for a refillable at the moment as I may find that I hardly ever use it.
                                        indecision Any ideas ? No problem using stick and a minor problem connecting air for cutting but argon looks to be a bit trickier – on the cheap and simple side of things.
                                        Muzzer
                                          @muzzer
                                          However you do it, argon will cost you. The best deal is probably the special arrangement that BOC has for hobby users. When I enquired in May this year, the rental costs were:
                                          Argon
                                          £73.54 / yr rental
                                          £42.68 refill
                                          Argoshield light:
                                          £50.89 / yr rental
                                          £34.87 refill
                                          They are prices with VAT. PS they are for the large (X?) size, not noddy bottles.
                                          I can give you the contact details for the application form if you like. I think you'll find these are pretty good prices.
                                          For TIG you need pure argon (optionally with some helium). For MIG with steel (technically MAG) you really need some CO2 in there too although you can also use pure CO2. It's very unlikely you will do any aluminium MIG for various reasons.
                                          Pretty sure the tiny bottle regulators are indeed regulators. Argon doesn't liquify so the pressure varies proportional to the amount in the bottle. You'd have appalling regulation with just a flow restrictor and if you tried to turn the gas off downstream you'd have an interesting back pressure to contend with.
                                          Murray
                                          Edited By Muzzer on 15/12/2016 20:02:31
                                          #272072
                                          peak4
                                            @peak4
                                            There's a fair number of rent free options these days, Just have a look with your favourite search engine for "Rent Free Welding Gas"
                                            #272074
                                            Muzzer
                                              @muzzer
                                              We've been through all of this before. There's a thread here.
                                              These "rent free" deals don't give you something for nothing – you end up having to buy the bottle and the gas costs more.
                                              Read through the thread, check the latest prices and make up your own mind. As I said, I think you'll find the BOC hobby deal is pretty attractive….
                                              Murray
                                              #272101
                                              Ajohnw
                                                @ajohnw51620
                                                Thanks Murray. There are 2 BOC depo's around here. Or at least I think so. One in Redditch. Further but a lot less traffic.
                                                One awkward for me to get to in B'ham supplier does a one off deposit on the bottles. £80 deposit for a 20L with 4m^3 gas refundable and £96 for a refill. That's 3' tall. A 2L may be suitable for me. £25 deposit and £26.40 for the gas. Or a 9L, 30" tall for £55 and £48. They state pure argon. I did know about that. A place I worked at tried medical argon what ever that is and it didn't work out.
                                                Not sure if I can compare these prices with BOC directly. No signs of what their rental charges are and there seems to be a charge for collecting refills – £14 ??. BOC's PD size is ar 230bar and contains just short of 500l of gas. The other's 2L one is at 200 bar and contains 420L of gas. I think I can assume usage is 7 L / min So circa 1hr of welding. Their 9L one looks to be a good option for a "small one" – 1.2m^3 gas. An hour of solid welding in my terms is a lot. Nearly 3hrs should be OTT.
                                                This is the outfit selling gas like this
                                                I'll phone BOC and get actual prices but suspect if they do charge £14 odd for collect I'll buy from these people.
                                                cryingLooks like disposable is out but at least I could get my deposit back if I find I have little use for it. I like stick welding and hope I can still cope with it.
                                                Not sure what argon light is for ?? Not sure about welding aluminium either. There is a youtube video showing it being done with DC and not totally sure but think I was using DC when playing with fusing 1/4" plate. That's why I had a nose around youtube.
                                                I took a look inside it. Looks pretty workman like to me. Neat and tidy. Not that this means a lot in terms of electronics. It comes with some collets etc and fittings for the cutter. Looking at the rating of commercial units there is a slight chance it will cut 6mm cleanly. Not much chance just a slight one. They claim 8mm but other units give 2 figures. A clean cut and I assume a bit of a mess.
                                                More posts since I finished this one. Thanks. There is at least one other local no rental supplier around but they don't  state prices – phone and ask. I'll look for more tomorrow.
                                                Edited By Ajohnw on 15/12/2016 23:16:08
                                                #272108
                                                John Stevenson 1
                                                  @johnstevenson1
                                                  Argon, I pay £4.99 per month rental less Vat but not sure what the refill price is, i think it's about £35.
                                                  Don't have any MiG gas invoices handy
                                                  These are the large bottles, in fact they stand about 6" taller than the BOC or Air products.
                                                  Small oxygen 3' tall is £4.50 per month rental and £7.00 for the refill.
                                                  This is from Gas Direct at Newark
                                                  #272193
                                                  Ajohnw
                                                    @ajohnw51620
                                                    Help !
                                                    I would seem sensible to get a single stage regulator and a flow meter. This is one for instance
                                                    But I take it that the gas connection on a cylinder comes out at 90 degrees so to get the flow regulator pointing upwards the bottle would have to be lying on it's side.
                                                    Am I missing something or does it need another connection of some sort as well? This one is preset to 3bar too. Some come set to 2 bar.
                                                    The same sort of arrangement is available from lots of sources and all seem to be the same..
                                                    Nick Hughes
                                                      @nickhughes97026
                                                      John,
                                                      Get your yourself on **LINK**
                                                      All in a decent bunch of guys and in my experience, very helpful.
                                                      Nick.
