tailstock
tailstock
Home Forums Workshop Tools and Tooling tailstock
  • #269967
    mick70
      @mick70
      can i use any tailstock with a rotary table?
      or do i have to use the one for that model table?
      #18299
      mick70
        @mick70
        #269971
          Most tailstocks [that are intended for use with Rotary Tables or Dividing Heads] are adjustable for height and angle … Therefore any of these, of the right general size, should be O.K.
          Edited By Michael Gilligan on 05/12/2016 10:29:04
          #269973
          mick70
            @mick70
            thanks for that.
            thought it might be case but wanted to make sure.
            #270488
              I made up some simple kit to align my Rotary Table on the Mill/Drill in both Vertical and Horizontal modes.
              With the Table set for Horizontal use, I used the equipment to align the Tailstock (very lightly clamped to the Mill table) with the Rotary Table, before tightening the locking bolts for height and Angle adjustments.
              This aligned the Tailstock horizontally with the Rotary Table.Table at the same time. This used the the O D of the tailstock centre, which had already been set in a 4 Jaw Chuck on the lathe, to run true within 0.0005", and the Centre trimmed up . In fact the tipped tool merely polished the Centre, so I need not have worried.
              At least I could now be reasonably confident that the Tailstock Centre would be well aligned with the axis of the Rotary table.
