Cast iron axleboxes v horns
Home Forums Locomotives Cast iron axleboxes v horns
  • #381285
    John Billard 1
      @johnbillard1
      Using the castings I have available for a 5" loco is it acceptable to use cast iron for both horns and axleboxes?
      Best wishes
      John B
      #1773
      John Billard 1
        @johnbillard1
        #381343
          It should be, teh graphite in most cast iron stops it picking up when run on itself, unlike most metals.
          #381546
          John Billard 1
            @johnbillard1
            Thanks Neil. As a friend has pointed out think of slide valves and pistons in cylinders . He observes that cast iron is the only metal that can be run together. Obvious really.
            Kind regards
            John B
