AC motor speed controler
Home Forums Workshop Tools and Tooling AC motor speed controler
  • #16811
    Mark P.
      @markp
      #90285
      Mark P.
        @markp
        Hi chaps,does anyone know about or have any thoughts on this speed controller on Ebay would it be any good for a small lathe or a waste of money?
        Regards Pailo
        Edited By David Clark 1 on 06/05/2012 16:57:54
        #90287
        Sandy Morton
          @sandymorton10620
          Hi Pailo
          It depends upon what you mean by a small lathe – I think that this could be borderline for an ML7 motor but would be fine for anything smaller.
          #90296
          John Haine
            @johnhaine32865
            Will not work on an induction motor! Designed for series wound motors. Avoid I suggest.
            #90304
            Steve Garnett
              @stevegarnett62550
              It is literally what it says it is – it's a power controller. Basically a posh light dimmer. So with a typical induction motor, the unloaded speed wouldn't alter much if you turned the control down. If you load the motor, though, it will slow down, because the reduced power can't move the load as fast. So, the motor's speed will vary according to the load…. pretty much the last thing you'd want on a lathe!
              #90308
              Mark P.
                @markp
                Hi Steve.thought that all it was ,will leave well alone but it was only a thought.
                Regards Pailo.
                #90319
                David Littlewood
                  @davidlittlewood51847
                  An induction motor will always run at a speed synchronised to the supply frequency. Actually it will slip a little, according to load, but if it gets much slower it will stall (and then burn out unless switched off pronto). As Steve said, if this is just a thyristor contoller which reduces the average power supplied by truncating the AC waveform by varying amounts, then it will not alter the speed of this type of motor, though it is likely to make it stall more easily under load as the power is reduced.
                  It is possible to vary the speed of a single-phase induction motor, but only by feeding it with a variable-frequency AC source. Controllers of this type can be bought, but not at that price. I am no expert, but I would hesitate to recommend them for use in machine tools, as the speed regulation under load is not too good, and the motor might be sluggish to start if the speed setting is high. A 3-phase motor and VFD is by miles the best way to go to get variable motor speed.
                  David
                  #90325
                  Mark P.
                    @markp
                    Thanks for the information,have now dismissed the Idea!
                    Regards Pailo.
