Rust Removal
Rust Removal
Home › Forums › Workshop Techniques › Rust Removal
  • #15933
    Martin Faulkner
      @martinfaulkner67684
      Not sure if it’s any use to anyone
      #293815
      Martin Faulkner
        Made a start on cleaning my lathe up and all the bits to go with. Here is a sample by the way of electrolysis. For those of you that have not tried it and want to see results. Here you arecollage 2017-04-17 17_46_04.jpg
        #293823
        oldvelo
          @oldvelo
          Hi Martin
          Having used this technique for a number of years on various restoration projects can I point other readers to
          http://antique-engines.com/electrol.asp
          Wire brush of Blackened oxides under running water and remove excess water the spray with WD 40 Or CRC Water Repellent.
          A Blackening process to finish off.
          Eric
          #293824
          Martin Faulkner
            Great followup. Was not sure if it was of interest to anyone. I am new to this forum so don't really know the lay of the land sort of speak.
            Can I also add, get a small wire brush, for small parts, I think I have lost half of the skin on my hands today using a normal one.
            #293829
            Vic
              @vic
              I've used Electrolysis for cleaning rusty stuff quite a few times now. It works great and doesn't etch the surface like citric or other acids do.
              #293862
              Andrew Tinsley
                @andrewtinsley63637
                I use hot diluted phosphoric acid and that works well too.
                Andrew.
                #293873
                  Get some oil onto them ASAP as soon as they are out of the water.
                  Martin Faulkner
                    Posted by Andrew Tinsley on 18/04/2017 09:56:01:
                    Andrew.
                    Not heard of that one, does it require scrubbing after the hot acid process and does it react or eat away at the good steel?
                    #293986
                    Martin Faulkner
                      Andrew.
                      #294888
                      Andrew Tinsley
                        @andrewtinsley63637
                        Hi Martin,
                        I am sure it does attack the steel, but only if you leave it in too long. It seems to go for the rust first. I did put in a large reamer with some rust on it. I left it in too long and the bright steel went a satin colour, but the rust was long gone.
                        I purchased 5 lts of conc stuff on Ebay. I dilute this down approx. 10 to 1 with very hot water and dump stuff in. It seems that hot is the key. Once it has cooled down a bit, then you can fish stuff out by hand and the acid doesn't affect my skin!
                        Andrew.
                        #294889
                        Andrew Tinsley
                          @andrewtinsley63637
                          Hello again,
                          I think the recent post on rust removal using a non acid chelating agent is the best bet, but I can't find the thread!
                          Andrew.
                          #294891
                          Nick_G
                            @nick_g
                            Posted by Andrew Tinsley on 25/04/2017 14:44:42:
                            Andrew.
                            Do you mean **LINK** this one.?
                            Nick
                            #294896
                            MW
                              @mw27036
                              I'm probably more of a brute than a chemist which is why i mainly use a wire brush at high speed to clean up steel. Does a wonderful job on most stuff.
                              Michael W
                              Edited By Michael-w on 25/04/2017 15:39:58
                              #296224
                              Neil Fazakerley
                                @neilfazakerley
                                Posted by Martin Faulkner on 18/04/2017 22:46:37:
                                Andrew.
                                I believe phosphoric acid is actually one of the ingredients of Coke. Maybe you could soak parts in hot Coke?smiley
                                Just don't drink it afterwards.smile p
                                #296225
                                Neil Fazakerley
                                  @neilfazakerley
                                  Posted by Vic on 17/04/2017 23:33:33:
                                  Apparently tea makes a good electrolyte for rust removal. Takes a long time though.
                                  Same advice as my post abovesmile p
                                  #296505
                                    Posted by Neil Fazakerley on 03/05/2017 17:43:43:
                                    Andrew.
                                    I tried using cheap'n'cheerful sugar free 'cola'. It worked fine (left in the garden) but took a few days.
                                    It turned the cola into Irn Bru.
                                    Edited By Neil Wyatt on 05/05/2017 11:00:08
                                  Home › Forums › Workshop Techniques › Topics
