Well here it is nearly finished been a few interesting weeks making this.
When i make the next one i will silver solder the boiler tubes in much neater.
The rest i will defiantly Tig weld i am lucky to have the use of a 350 industrial Tig Welder that will run at over 220 amps is what it seems to get good welds and penetration.
I can't wait to build another one i was so afraid at first every step was worried i might do it wrong.
At each stage i have taken to boiler inspectors so they could check at each stage found them very helpful.
I hope to fit front bush i have now made for super heater then i can fit the stays and get it pressure tested.
Started on the Regulator going to use cheese type in a 7/8 copper tube i am hoping its all in line so i dont have to use linkages as suggested.
My boiler is just an inch bigger than standard taper boiler i think this will give me the clearance i will need (i hope)
fingers crossed to see if pressure test goes ok
Ron
