Sam, just digging through my handbooks again –
In fact, the motor on the Super-11 mill is the same as on the stand-alone mill. If you look at the top right of your label – the RBP0.18 denotes a 0.18KW motor.
The standalone mill motor nameplate indicates 220v, 1.7amp, 0.18KW
You motor says 240v 1.9amp, 0.22KW – the extra bit comes from the increased aloowed voltage…But the motor is in fact the same motor. In the handbooks it indicates the capacitor is 6uf @ 240V supply and 8uf @ 220VAC – not sure what your supply voltage is, but if it is closer to 220V, I would rather fit the 8uf cap…better starting on those cold oil mornings…
Enough..
Joe
Joe
