J&S540 Homebrew power rise and fall.
Home Forums Manual machine tools J&S540 Homebrew power rise and fall.
  • #213148
    David Colwill
      @davidcolwill19261
      The drill seems to manage with no problem.
      Regards.
      David.
      #12584
      David Colwill
        @davidcolwill19261
        A quick but useful accessory.
        #213159
        Muzzer
          @muzzer
          I do a similar thing with my rotary table although that requires a hex bit. Handy for turning it during setup. Main problem is the hex bolt working loose if you turn it anticlockwise. Your last photo is fuzzy – is there a locking device there at 3 o'clock?
          #213163
          David Colwill
            @davidcolwill19261
            Ahh sorry about that, the lighting isn't so great there. I'm not sure how the dial fixes on or what that third screw does tbh . The shaft that fits the drill is threaded M12 and screwed on with superglue. If it unscrews in use I'll pin it but it seems ok at the moment.
            David.
