Blown Mill Motor
Blown Mill Motor
Home › Forums › Manual machine tools › Blown Mill Motor
  • #12228
    Gray62
      @gray62
      Ajax AJT4 Varispeed
      #138309
      Gray62
        @gray62
        Sadly this evening, the spindle motor on My Ajax mill let out all of its stored smoke.
        It's a varispeed head very similar to the bridgeport, 3HP motor. does anyone know of a source for a replacement or a motor rewinder in the Hampshire area
        #138310
        KWIL
          @kwil
          AES Rewinds in Farnborough will sort you OK, not too far either.
          K
          #138319
          Gray62
            @gray62
            Thanks Ken, I was wondering if they were still around, have found their details so a visit will be in order very soon, off out to strip the head down now, not quite how I had the evening planned
            Graeme
            #138320
            John Stevenson 1
              @johnstevenson1
              At 3HP don't bother with a rewind, it will cost x 3 what a new motor costs.
              Get the motor off, take some pictures of the flange and shaft fitting with dimensions, then get the price of a rewind and new motor.
              Chances are you won't get a motor to the exact fittings you want but new motors can be modified to match.
              This is something I do all the while.
              #138334
              Gray62
                @gray62
                John, I suspected that may be the case, any motor I get will need some modification, this is the one from the mill
                and the rating plate
                Any recommendations gratefully received.
                Graeme
                #138338
                John Stevenson 1
                  @johnstevenson1
                  You need to strip the pulley arrangement to check for wear as this could affect any rebuild prices from AES but go ahead and see what they say as they are local to you.
                  Chances are I can supply a new quality motor and convert it cheaper than they can repair it. Not saying anything against AES, I don't even know them, but I deal with three rewind companies local to me so I know how they work.
                  #138366
                  mgnbuk
                    @mgnbuk
                    As Lagun are still in business & still make a version of this machine, it may be worthwhile asking them direct for a quote.
                    Most UK machine tool agents do rather "over egg" their spares prices, but I was (pleasantly) suprised at my last employment when I contacted Spanish manufacturer Zayer direct for a price on a set of 4 spiral bevel gears for a double angle universal head – a UK gearmaker had quoted several thousand to make a set to sample, where the OE parts were £500 and ex-stock. Carriage costs were not excessive either.
                    Contact details here : http://www.lagun.com.es/sat_en.html
                    Might come to nothing, but also costs nothing to ask.
                    #138368
                    Gray62
                      @gray62
                      Hi John
                      As suspected, not worth a rewind, minimum £350+vat
                      There doesn't appear to be much wear in the pulley sheaves although whilst I have it off the machine I guess its worth returning them at the same time.
                      Graeme
                      #139172
                      frank brown
                        @frankbrown22225
                        About 10 years ago I got a dual speed 3 ph. 2.2/3KW motor rewound for £154 at a place in the Nursling Factory estate (W. of Southampton). Sorry I can't remember its name.
                        Frank
