Zeroing a mechanical digital micrometer
Home Forums Beginners questions Zeroing a mechanical digital micrometer
  • #100791
    Gordon Henderson 3
      @gordonhenderson3
      Hi folks,
      I purchased a micrometer which has a digital display operated (I assume) through some kind of gearing from the spindle. The micrometer can be read in the conventional way using the sleeve and thimble, and I have corrected the zero on these items. What I find I cannot do, is to zero the digital counter. I have instructions, but they are not very well translated from chinese, and are not much help. Currently, with the sleeve and thimble zeroed, the digital counter is reading 99.856mm.
      I tried searching the internet but was not able to find anything to assist me, so if anyone can help, I'd be very grateful.
      Thanks,
      Gordon
      Gordon Henderson 3
        @gordonhenderson3
        #100868
        mick
          @mick65121
          I assume you have used the zero button? When zeroing any micrometer the anvil faces must be completely clean. Place a thin piece of paper between the anvils and close them together using only ratchet pressure, then pull the paper out, the mic should read zero when closed with ratchet pressure, this is the point where you must zero a digital micrometer. If a digital mic is still not zeroing properly then try cleaning the contact face of the battery, or replacing it with a new one.
          #100872
          Ady1
            @ady1
            If you can upload a picture of it that would make things a lot easier
            #100874
            Ian Parkin
              @ianparkin39383
              Gordon may be refering to the other type of digital micrometer ???
              http://i417.photobucket.com/albums/pp251/ianpark1/DSC01150Medium.jpg
              I should imagine that there would be a method of removing the counter mechanism and reseting the gear chain
              Ian
              Edited By Ian Parkin on 15/10/2012 10:46:31
              #101013
              Gordon Henderson 3
                @gordonhenderson3
                Thank you for the replys and, yes Ian, it is one of those you illustrated.
                I have removed the small screw as suggested by Graham, but must be doing something wrong as I still cannot get the zero points to coincide. Fortunately, I have an engineer friend I can ask at some point in the near future.
                Again, thank you all for your help.
                Gordon
