workshop quries
workshop quries
Home Forums General Questions workshop quries
  • #265370
    korby
      @korby
      This is an Alan west contactor,the plastic pots were oil filled dash pots intended to slug the overload trips on the motor starting surge.
      Even if it has three poles you can use it on single phase by wiring two in series.
      Dad had one on his ml7 many moons ago worked ok but tended to buzz a bit.
      Also the thin oil tended to leak out over time.
      Probably not so important with modern motors tthat can withstand overloads better than oldies.
      #24849
      korby
        @korby
        #265372
        korby
          @korby
          The above post of course refers to the mystery switch photo in albums,should have made this clear oops.
          #265373
          Emgee
            @emgee
            korby
            Did you intend this to be in the "Electrics are definitely not my forte" which is where the Allen West starter is pictured ?
            Emgee
            #265374
            korby
              @korby
              Sorry brain is not fully functional this early in the morning
