Hello John, the lathe is fitted with a 10 amp fuse as standard, I expect it is a quick blow type. The main fuse at the plug is 13a.
Mark P
Mark given that 10amps is more than 2000 watts….that's approaching 3hp territory……
What size motor is in your machine?
Even if the fuse is a quick blow type, the scr's will blow a lot a faster….
My recommendation fwiw, is to replace the fuse with that of a lower rating, even going to the lowest value that doesn't blow under normal use….
My Chester mini mill is fitted with a 3 amp fuse in the plug, the motor is rated at 550 watts (3/4hp….) ok the fuse is borderline at say 690 watts (230v ac nominal? )……
Cheaper than buying a new board or the cost of the repair…..
Its down to individual choice…..
