Whirlpool cooker
Whirlpool cooker
Home Forums The Tea Room Whirlpool cooker
  • #560740
    Clive Hartland
      @clivehartland94829
      It looks as if the dreaded shortage of parts has hit me, my Cooker has blown the heater ring by the fan. Easy to fit, if I can get one.
      Order from Espares with a proviso it will be sent on the 15th Sept. as they are out of stock!
      Luckily I have a microwave.
      Clive Hartland
        @clivehartland94829
        #560741
        Ady1
          @ady1
          Steamed chicken?
          #560742
          Bazyle
            @bazyle
            I lived for a decade without a cooker, or microwave just slow cooker, grill and 2 rings. When I moved the new house had a cooker. Even then and before I got my first microwave I didn't and don't use it every month. Most of African households don't have an oven and before colonisation introduced them to bread they got on ok.
            #560743
            Clive Hartland
              @clivehartland94829
              Damn, just found a company who has one in stock, I will still wait for the Espares one and keep it as a spare.
              #560745
              pgk pgk
                @pgkpgk17461
                Bazyle
                Old saying: "You can boil eggs in a kettle, but you can't pour them out"
                pgk
                #560754
                Harry Wilkes
                  @harrywilkes58467
                  Posted by Clive Hartland on 01/09/2021 17:53:23:
                  Some years back B&Q failed to deliver my new cooker which should have been delivered Christmas Eve after a few heated calls it was was myself and my wife could eat out or order in one hot meal a day until the cooker was delivered needless to say it didn't arrive until the new year so I had a sizeable bill for them and they got off light as I went to daughters Christmas day for lunch !
                  H
                  #560759
                  HOWARDT
                    @howardt
                    A few years ago my oven failed about five days before Christmas. It was still under the manufactures warranty and the model had a inherent fault, it had a pyrolitic self cleaning oven which failed. Ended up cooking the turkey at my fathers, twelve miles away, the day before. Got a replacement model in the new year, which had to then be replaced as they sent the wrong one. Took six months for them to get it all sorted.
                    #560861
                    Clive Hartland
                      @clivehartland94829
                      The one from the stockist who has them is on the way. just checked their delivery.
                      #560888
                      not done it yet
                        @notdoneityet
                        Clive,
                        Is your cooker a fan assisted oven only? Our main oven has other elements including a grill (which needs replacing). Even the smaller top grill oven has top and bottom elements as well as the overhead radiant grill.
                        I often use a halogen oven and microwave and my wife likes to use one of the slow cookers (one for casseroles and one for chrissie puddings). Then there is the toaster and soup-maker….
                        #560973
                        Clive Hartland
                          @clivehartland94829
                          Not done it yet, Hi, yes it is a fan assisted oven and that is where the problem is. what happens the fan slows down and heating ring around the fan overheats and pops. It is very easy to fix as a few screws to undo and the cowl comes off. The two wires that come out you need to use a couple of pegs to stop thefalling back inside the panel.
                          I did fit a new fan some time back and serviced the old one in case of future need. Maybe I will fit it. I will see.
                          Managed a meal tonight, so thats OK.
                          #560979
                          KWIL
                            @kwil
                            A source of replacement Whirlpool halogen elements for a hob would be most usefull.
                            #560983
                            Oldiron
                              @oldiron
                              Posted by KWIL on 02/09/2021 19:37:17:
                              As pointed out by Clive, Espares seem to be one of the best suppliers of cooker parts. I have used them several times for cooker & fridge spares and they never failed me.
                              regards
                              #560992
                              Mike Poole
                                @mikepoole82104
                                You can guess when the element failed on our fan oven, the Christmas turkey had about 45mins to go. The microwave combination oven saved the day, the turkey was a bit of a squeeze though. The spare element will at least give you peace of mind, I should order a spare for my new cooker just in case.
                                #560998
                                DMB
                                  @dmb
                                  I had a double oven and grill by Hotpoint, fitted just 2.5 years ago with new kitchen. Main oven started smoking so knowing that the make is an 'also ran', if I got parts replaced under warranty, how long would I wait and how long would they last? I decided to make use of my Which? mags and selected a highly recommended Zanussi, delivered installed and tested by a local retailer who took away the busted one for free, normally charge £18. Very happy with the much better quality version.
                                  #561056
                                  Clive Hartland
                                    @clivehartland94829
                                    As the heating ring is on its way I have started to dismantle the heating ring and fan part of the oven, it has come apart OK, the heating ring has bubbled and has a small section burnt out.
                                    Now trying to get the connectors through the holes without getting them disconnected.
                                    The fan is free and rotates freely when spun. As I dismantled I am cleaning, dirty job.
                                    Worst biy is with my dicky back I am sitting on the floor doing it and then trying to get up is a painful task plus dog keeps coming up looking over my shoulder.
                                    Edited By Clive Hartland on 03/09/2021 13:43:37
                                    #561089
                                    Rod Renshaw
                                      @rodrenshaw28584
                                      I worked at one time for the Benefits Agency and overheard one of the team leaders speaking on the telephone to a customer who was in need of a replacement cooker just before Christmas. This customer had had many grants and loans in the past and his request this time had been refused. In answer to the question "what are we going to do for Christmas dinner?" the team leader replied, in an empathetic, caring voice, "Well, you could have a nice salad." The customer was not impressed.
                                      Rod
                                      #561108
                                      Howard Lewis
                                        @howardlewis46836
                                        Rod,
                                        The customer could try something new and exciting. Use a blowlamp / blowtorch and have flame seared chicken / goose / turkey (select to choice )! Do it on a spit, like they did centuries ago?
                                        But I am not a cook
                                        #561257
                                        Clive Hartland
                                          @clivehartland94829
                                          The new heating ring arrived and as I had already cleared the old one it was an easy fix.
                                          Nice clean oven now and i switched on and within a few seconds it showed OK. Job done.
