Posted by Paul Lousick on 26/01/2019 07:29:38:
You do not need much pressure (10-30 psi) but need a lot of volume. The little tyre inflating compressors, etc are the opposite. High pressure and low volume of air.
That's right, but you can shift the output towards high-volume low-pressure by adding a reservoir between the pump and the model engine.
With a foot-pump, an ordinary 2L fizzy drinks bottle will do – there's no danger of anything nasty happening because the human is in control. OK for a quick check, but working a foot-pump soon gets tired.
A motorised pump with a reservoir is more convenient and less safe; it needs to turn off automatically when the reservoir is at max operating pressure, and back on again when the pressure drops. Additionally, there needs to be a regulator between the reservoir and engine, and a couple of pressure gauges and a throttle would be nice too. The reservoir has to be suitably strong with a drain-cock and reliable safety valve,
A quiet affordable pump well suited for supplying air to model engines doesn't seem to be on the market. It may be because most domestic requirements for low-pressure high-volume air are met by fans. For this purpose fans aren't much use because they churn inefficiently at engine pressures.
Instead people adapt things like air-brushes and a variety of less suitable pumps. Given the need and the fact we all have machine tools, it's odd that no-one has designed an engine compressor yet – or have they? It would make an interesting project!
Edited By SillyOldDuffer on 26/01/2019 09:57:27
