What to do with a old bench lathe (relmac)
Home Forums Manual machine tools What to do with a old bench lathe (relmac)
  • #326673
    Rainbows
      @rainbows
      Some people are born with lathes and some have lathes thrust upon them
      I now have a Relmac of average conditions with what appears to be all parts and a 10 year old layer of grease and dust along with its makers cast iron stand.
      I have my Keighley for big stuff and CJ18A for small stuff. The Relmac sits there as a more worn out, obsolete version of the CJ18A. Apart from sticking it on ebay, the easy and sensible option, are there any alternate uses for a small lathe? Some other machine to use it as a base for?
      Rainbows
        @rainbows
        #326679
          [if you have the space] …
          Might be worth keeping it for grinding/lapping/polishing work; to keep abrasives away from the others.
          Or put a milling/drilling spindle onto it, and use it as dividing/graduating machine.
          Dave Halford
            @davehalford22513
            Pass it on, I have an old T&LM and when I get the back gear replaced on my Rockwell 10" the T&LM will go on ebay as I need the space.
            Only use I can think of is perhaps leave it set up for boring work, the tee slot table would help with that.
            #326718
            richardandtracy
              @richardandtracy
              Anchor for your yacht?
              Failing that, E-bay seems sensible. Better it sees use than take up space to no purpose, or is wrecked by use as a grinder bed.
              Richard.
