What steel to use
What steel to use
Home Forums Beginners questions What steel to use
Viewing 25 posts - 1 through 25 (of 25 total)
  • #97980
    chris j
      @chrisj
      I have been looking at some plans for various bits of kit and noticed that Harold Hall notates his drawings with a numbers like Steel 230M07 and Steel 080A15.
      What do these numbers denote and are there lists of the different kinds ?
      chris j
        @chrisj
        #97984
        Brian O’Connor
          @brianoconnor49474
          Hi Chris,
          They are BS numbers, which replaced the old wartime EN numbers back in the 70s. The first one, 230M07, is a free-cutting carbon steel (the 2) having 0.3% sulphur (30) and 0.07% carbon (07). The M denotes that is complies with required mechanical properties. It is the same as the old EN1A, the steel so beloved by model engineers.
          The 080A15 is a 'straight' carbon steel (0) having 0.8% manganese (80) and 0.15% carbon (15). The A denotes that it complies with required chemical properties.
          Every country seems to have its own set of standards but there are cross-reference lists on the web, often on steel manufacturers' sites. I have such a list but can't remember where it came from. If you are interested I'm sure that Googling 'steel grades' or something similar will bring up something.
          Regards, Brian
          #97985
          chris j
            @chrisj
            That's great Brian, thanks.
            #98000
            Wolfie
              @wolfie
              I generally get my metal from M Machine in Darlo cos they are local. When you look at their listings they will provide the BS numbers. I have to assume that other suppliers do similar..
              #98001
              chris j
                @chrisj
                Posted by Wolfie on 08/09/2012 23:33:34:
                Yes my local supplier will use numbers but they don't mean much to me at this point in my engineering life. smiley
                For example the two numbers in the OP that Brian explained in great detail for me (thanks) however it went over my head a bit. That said I realise I can't expect eveyone to spoon feed me info but it gives me something to work with.
                #98002
                David Littlewood
                  @davidlittlewood51847
                  Chris,
                  You might find this book quite a useful introduction to most of the materials of use to model engineers, including the commonly used steel grades: **LINK**
                  David
                  #98003
                  chris j
                    @chrisj
                    Posted by David Littlewood on 09/09/2012 00:03:44:
                    Chris,
                    David
                    Brilliant thanks
                    #98030
                    Harold Hall 1
                      @haroldhall1
                      Having Chris J referred to the specification numbers I quote for my projects I feel I should comment. There are hundreds of steel specifications but only a handful will ever find a place in the home workshop and of the handful two are likely to cover 99% of all steels required in the majority of workshops.
                      230M07 (very close to EN1A in the earlier spec) is only available in rounds, hexagons and a limited number of square sizes, and is predominantly a free cutting steel intended for use on the lathe. A version of this with a small amount of lead added machines even better and is known as 230M07Pb. Unfortunately, very few of those supplying the home workshop stock this.
                      080A15( previously known as “good commercial quality&rdquo is available in the above shapes but also in a very wide range of flat sizes. Because of this it is a material for use on the milling machine. However it machines less well than 230M07 so is not ideal for turning, though of course can be.
                      070M20 (very close to EN3B in the earlier spec) is a number I now quote in preference to 080A15. This, whilst almost identical for most applications, is because it is more widely available from those supplying the home workshop.
                      This I feel is all you need to know for the vast majority of work you undertake, that is unless your workshop activities becomes very specialised.
                      A little more thought will be needed if you get into welding or case hardening which is possible with all the above (except when leaded) but there are preferences and would advise that the subject is researched when such a need arises. Similarly, if you start making parts that will be highly stressed, or need to be hardened, then cross that bridge when you come to it.
                      I terms of machinability, Macreadys in their catalogue use 230M07 as a base for which they quote a value of 100, for 230M07Pb the value is 130 and for 080A15 and 070M20 a value of 55.
                      Just to avoid confusion, Macreadys is a large supplier to industry and does not supply small quantities.
                      I would advise that you do purchase materials to known specifications and mark any left overs with some form of identification. Do Not purchase from suppliers who just state bright mild steel as you have no idea what is being supplied. Worse still, you will end up with some materials that machine well and some that machine poorly with out any knowledge of why.
                      We have seen questions to this forum where individuals ask why they are not getting a good result but do not know the steel they are using. Comparing 100 with 55 above shows that there can be quite a difference even with commonly available steels.
                      Hope this help ChrisJ
                      Harold
                      #98031
                      chris j
                        @chrisj
                        Thanks everyone for all for the help.
                        Good answer Harold, nice for a learner driver like me !
                        Chris
                        #98032
                        Harold Hall 1
                          @haroldhall1
                          How come the smiley, together with extra characters, appeared in my comments above?, I did not put it there.
                          Harold
                          #98033
                          chris j
                            @chrisj
                            Posted by Harold Hall 1 on 09/09/2012 15:04:14:
                            Harold
                            It's just a little comuter glitch is my guess.
                            #98034
                            Bernard Laycock 1
                              @bernardlaycock1
                              I think you're gilding the lily a bit. Most of the model engineer suppliers that I'm aware of don't quote the BS numbers for any of the metals they supply, indeed I remember phoning one to ask if they sold EN1A steel and the reply was "All our steels are free-cutting". And stainless steel is even worse.
                              If anyone can tell me the name, address and phone number of a supplier who even knows about metal grades and is prepared to sell small quantities, I would be delighted to shop with them.
                              Bernard
                              #98035
                              Russell Eberhardt
                                @russelleberhardt48058
                                A useful table showing these steels can be found here.
                                Unfortunately this numbering system (to BS.970) has been superceded by that in BS. EN. 10027 which I find very confusing and gives very little information as to what each grade is suitable for.sad It even gives two distinct systems of classification, a symbolic and a numeric one.
                                Here in France most suppliers stick to the old French system.
                                Russell.
                                #98036
                                chris j
                                  @chrisj
                                  Posted by Bernard Laycock 1 on 09/09/2012 15:45:51:
                                  Bernard
                                  Bernard
                                  This guy seems very knowledgable and likes to chat.
                                  He is in Great Yarmouth but will have whatever you want delivered straight to your door.
                                  Chris
                                  David Littlewood
                                    Harold
                                    Harold,
                                    I drew David C's attention to this problem last month; see: **LINK**
                                    David
                                    #98040
                                    David Littlewood
                                      Bernard,
                                      I think you have been a little unfortunate in the metal supplier you approached. I have found the chaps at Mallard Metal Packs, **LINK** and Noggin End Metals, **LINK** are both helpful and knowledgeable, and are often able to source specific grades of metal not in their normal catalogue.
                                      David
                                      #98047
                                      Harold Hall 1
                                        @haroldhall1
                                        The following Bernard are two suppliers who advertise in ME/MEW and who stock a vast range of metals, not only steel but many others, some special.
                                        In almost all cases they quote either the earlier of present day specification numbers.
                                        MK Metals even supply additionally to EN1a/230M07 the leaded versions.
                                        MK Metals at **LINK**
                                        M-Machine at **LINK**
                                        If a supplier states only bright mild steel then this is probably what they ordered. If they had ordered, say ENI A, surely they could quote in the catalogue Free cutting mild steel EN1A.
                                        If then they only ordered bright mild steel they are at the mercy of accepting what ever the supplier chooses to supply, which may differ from batch to batch
                                        I am presently trying to use up steel that I purchased before I took this decision to be more demanding as to what I am being sold. As a result, I often find myself using material that does not machine as well as I would like and am very tempted to dispose of it as scrap, but the bank manager part of me often prevents that..
                                        Harold
                                        #98051
                                        Sub Mandrel
                                          @submandrel
                                          metals Supermarket give the EN numbers of all their steel, including short ends, and have a wide selection. I have EN1A in 1 1/2" and 2 1/4" bar at the moment, and straight square EN1A which machines almost as well.
                                          jason udall
                                            @jasonudall57142
                                            Just a thought …
                                            Model engineers are not alone in "having trouble" with "new" EN specs Eg EN 230M07
                                            At work we are increasingly seeing drawings with EN numbers ( not to be confused with EN1A)
                                            so faro good..now customer wants this spec and this spec only needs mill cert. for metal
                                            BUT has to say (for exmple) EN 230M07 . A mill cert. declaring EN1A will not do.
                                            No the mill can't put both on cert. or supply cert saying (for exmple) EN 230M07..
                                            nor can any other mill…."funny" says customer.."had all our suppliers saying them same thing…"
                                            crook
                                            Used En1a as example but real nightmare in bronzes even when the specifed bronze has wider spec. than an available alloy…
                                            So you are not alone ,at least many tables of equivalents are available online to model engineers and sec.s are "converted" easily…shame customers can't read for themselveswink 2
                                            #98129
                                            Nathan Sharpe
                                              @nathansharpe19746
                                              While not quite on topic but still a "materials" point, I emailed CES today and had my mail intercepted by "Spamarrest". They asked me to verify my email address before me email would be forwarded to CES. Anyone else had this happen? I will delete the email and phone them instead.
                                              #98130
                                                Yep, just verify your mail and it will then get through.
                                                J
                                                #98131
                                                Terryd
                                                  @terryd72465
                                                  Hi all,
                                                  I thought that EN stood for 'Emergency Number' and was a wartime specification, so why does the latest spec number include them, as per Jason's posting?
                                                  Confusedly,
                                                  Terry
                                                  #98133
                                                    I think its people getting confused with the BS 970 number such as 230M07 and the European standard EN numbers which would be EN 1.0715 both of which are good old EN1A
                                                    J
                                                    Edited By JasonB on 10/09/2012 21:54:09
                                                    #98139
                                                    jason udall
                                                      @jasonudall57142
                                                      Sorry forgot to mention that EN also refers to European Normative….Have also received DIN EN1A as spec. on a drawing(same customer !) to which we also got same reply.." ….no mill cert. must be exactly as on drawing…."…you couldn't make it up…. Just trying to point out automotive industry drawing offices also "unclear" on standards….
                                                      Way back in '99 we had to make declaration for every part,,"the parts supplied will continue to process time and date correctly before ,during & after midnight 31 Dec. 1999/1 Jan 2000.." pretty sure that the turned parts would CONTINUE to do so at least as well as they did before… again same firm.
                                                      And as to "when will your components be leadfree?"..deserved one answer.."when the drawing no longer specifies leaded alloys(LB4 AND ENIA Pb in that case"..
                                                      ….btw unleaded alloys still may have enough lead to be "leadbearing" for COSHH…
