What is this?
What is this?
Home Forums Beginners questions What is this?
  • #266205
    Allan Coombs
      @allancoombs96502
      Hi
      The control knob/cylinder has teeth about the circumference as does the two larger disks.
      Haven't a clue what it is or if its all there?
      Cheers
      AL
      #8386
      Allan Coombs
        @allancoombs96502
        Tool
        #266208
        mechman48
          @mechman48
          Looks to me like some sort of camera lens holder / extension tube bits, just guessing dont know
          George.
          Edited By JasonB on 12/11/2016 18:18:39
          #266211
          Clive Hartland
            @clivehartland94829
            All those pieces are part of a close up lens mount, what is missing is the slide bars and the rack and the bellows between the lens and the camera. Hard to say what camera or what camera it is for but most camera makers have a bellows rack for their system. It will utilise the standard 50mm lens and allow in most cases 1/1 enlargement of the close up item/specimen.
            Clive.
            Edited By JasonB on 12/11/2016 18:18:56
            #266214
            Rik Shaw
              @rikshaw
              Allan – Don't know but I'll take a guess. Bits from a photographic enlarger?
              Rik
              #266219
                Allan,
                I think they're part of the Fotga 'follow focus' system [or similar]:
                http://www.ebay.co.uk/itm/Fotga-DP500-Follow-Focus-and-Camera-Rail-System-Lens-Support-DSLR-/262707872277?hash=item3d2a9c0215:g:CBAAAOSw4GVYH3Fq
                https://m.youtube.com/watch?v=vq0a85yNonI
                Edited By Michael Gilligan on 12/11/2016 17:18:50
                Edited By JasonB on 12/11/2016 18:19:13
                #266220
                Clive Hartland
                  @clivehartland94829
                  All the bits are off a bellows type close up lens system. The rails are missing and the rack plus bellows. The slot in the ring is for a ruler as it is extended or closed back. Normally used with the standard 50mm lens off the camera, also has a system that will operate the iris to close down after focussing the lens.
                  #266757
                  Allan Coombs
                    @allancoombs96502
                    Many thanks for all your posts.
                    Sorry to put it on here but I didn't know what is was and guessed part of a jig or something as it was in a box full of machine tools.
                    That will teach me not to assume
                    Cheers
                    AL
                    #266758
                      No problem at all, Al
                      At least it has an engineered look about it … You should see some of the ridiculous discussions we have on this forum !!
                      Put it up for sale for a few coppers and I might be tempted
