what do you use when designing?
Home › Forums › General Questions › what do you use when designing?
Viewing 25 posts - 1 through 25 (of 72 total)
  • #262144
    mick70
      @mick70
      Just been reading on another forum about what people use when designing stuff.
      was quite surprised how many people still do it by hand.
      i admit i do it on drawing board by hand as don't get on with electronic gizmos.
      even carry small pad to put ideas on or make notes for if i see something i like idea off, wish i did as would love to have go at 3d printing.
      so what does everyone else use?
      #24816
      mick70
        @mick70
        #262145
        Gary Wooding
          @garywooding25363
          I've been using TurboCad for a number of years now, but have started to switch to Fusion 360 which, for hobbyists etc, is totally free.
          #262146
          Paul Lousick
            @paullousick59116
            Worked as a draftsman for 40 years, drawing board, Autocad, ProEngineer and Solidworks. Do most things now in Solideworks.
            Paul
            #262152
            Martin Connelly
              @martinconnelly55370
              I use 3D AutoCAD at work so use it for personal design work as well when needed. Pen and paper is used when that is all I need. Tools to suit the work required.
              Martin
              #262154
              JA
                @ja
                I was weaned off using a drawing board at work and now use TurboCad. I would dearly like to use what we had at work. It was far better and more powerful than Autocad and TurboCad but I would not be able to afford it. Having retired eight years ago I can't even remember what it was called.
                JA
                #262156
                loco man
                  @locoman67579
                  Again, draughtsman for over 40 years. Drawing board at first then, from 1978, primarily CAD. Including Computervision, Radan Radraft, Tektronix, and Microstation. Initial design sketches with pen on sqared paper then CAD (at home), with A4 prints to take into the workshop. Trained to draw to the (old) BS308 and still much prefer and use it as black lines rather than 'colour coding'
                  #262158
                  John Hinkley
                    @johnhinkley26699
                    With no formal training in either engineering or draughtsmanship, I do all my 3D designing in my head. It's far easier to scrub out and start again if you get it wrong! Once the general layout is straight (in my head), I then go to my 2D CAD program and put it down on screen. It goes through many iterations before I come up with what I want and then I start a new drawing, cutting/pasting/rotating the various individual parts within this new file to make sure everything "fits together" and, as far as possible, doesn't clash with other areas of the design.
                    Suits me and I expect you'll get as many different answers to the original question as there are respondents. Whatever feels right for you, with the resources at your disposal, is what you should use.
                    Here endeth this morning's lesson.
                    Bikepete
                      @bikepete
                      Fusion 360 for 'big projects' but simpler stuff and odd jobs just get a quick sketch on a scrap of paper.
                      #262164
                      RobC
                        @robc77385
                        I usually start most ideas with pencil and paper, as there are lots of constraints that are too fluid for a formal drawing.
                        Once the idea is fleshed out a bit more, I may use SketchUp for simple shaped 3D designs, or Autodesk Fusion360 for those needing more definition and control.
                        I usually finalise things using Draftsight, as it is my 2D drawing package of choice.
                        The best part of all of these choices is that they are all free, which is the right price for me!
                        #262167
                        Raymond Anderson
                          @raymondanderson34407
                          Siemens Solidedge or pen and paper, all depends on how complex the design is.
                          #262183
                          Anonymous
                            Initial ideas and thinking are done in my head, while sitting in my special engineering armchair. For simple jigs or parts, like studs, I just make a quick pen 'n' paper sketch with key dimensions. For more complex items where there are several possible arrangements I'll also make quick sketches with key dimensions to see if things wlll fit.
                            Once I've got a clear idea I use Geomagic (Alibre as was) to produce 3D parts and assemblies and then 2D drawings. But I also use Geomagic to try out ideas and make measurements for machining. For instance when making a worm wheel one question is how deep can I go with the gashing cutter while ensuring that the hob still has some material left to remove? It's an easy sketch on the computer. I am also exploring Fusion360, although my interest is primarily in the CAM facilities, and in particular HSM toolpaths.
                            I've been through the process of formal drawings to BS308 using drawing boards, with pen and pencil, but no longer use these, or 2D CAD systems.
                            I don't smoke, so backs of fag packets are out. I've learnt the hard way that trying to wing it in the workshop without having thought things through properly usually ends up with time and material being wasted.
                            #262184
                              With the Jovilabe I've used Excel and about twenty sheets of A4 to work out ratios, sizes and spacings.
                              Turbocad to prove it would all fit together in 3D.
                              CorelDraw for the 'artistic bits'.
                              The really valuable tool has been a sheet of 16 gauge brass on top of a bit of pine pallet wood with 1/8" holes so i could stick in a few spindles and sense check everything.
                              I did a tender at the weekend that wanted 'sketches' so I made a tentative 3D model in Turbocad and used a rendered and skeleton version plus a few pages of hand-drawn sketches with notes. Hopefully the computer drawings will evidence technical ability and the sketches imagination!
                              Circlip
                                @circlip
                                When helping a mate in the States via Skype, a pencil and pad, easy to hold in front of a camera. Stunned reaction was always "Have you just drawn that????" Easy to sketch while talking. Err, thirty years on a board helped although have a bit of paper telling me I can use AutoCAD. Have used "Doublecad" but regularly use Photoshop for tiffling and rescaling plans.
                                Regards Ian.
                                #262186
                                Dianne Best
                                  @diannebest69516
                                  With many years in engineering, I was proficient in AutoCAD but when I retired, I switched to progeCAD, a free AutoCAD look-alike, and I use SketchUp for 3D creations.
                                  The initial concept is usually developed with quick/rough sketches on paper but then I move to CAD to work out the details and specifics. Maybe because of my years of engineering, I like to develop a full set of detailed drawings so that anyone could build it. In the shop, I prefer to work to the drawings rather than designing on the fly. If I come up with a better way in the shop, I go back and revise the drawings.
                                  #262187
                                  Hopper
                                    @hopper
                                    Pencil and A3 paper for me when designing my latest Stirling engine.
                                    Pen and A4 lined writing pad for drawing up bits and pieces, tooling etc, out in the shed.
                                    Not a complete luddite though. I do have a pocket calculator in the shed, and sometimes I even use it.
                                    #262190
                                    Gordon W
                                      @gordonw
                                      Design usually done sat on the bus, or watching the telly. Drawing on the back of A4 paper, often just free hand, squared paper for more accuracy. Any tricky bits like crank motions etc. draw out on A3 board. All just for myself, so all that is needed. Ex draffy for 50 years, used autocad at work, drove me round the bend -to slow.
                                      #262239
                                      Thor 🇳🇴
                                        @thor
                                        Like others I make sketches using pencil and paper. For most of the CAD work I do I use an old program called Intellicad 2000, and DoubleCAD because the drawings can be easily imported into my (old) word processor.
                                        Thor
                                        #262246
                                        Phil P
                                          @philp
                                          Soildworks both at work and at home for me.
                                          Phil
                                          #262252
                                          Dave Smith 14
                                            @davesmith14
                                            Catia V5. I have on my work laptop.
                                            #262253
                                            Spurry
                                              @spurry
                                              Another vote for TurboCad.
                                              Pete
                                              #262283
                                              duncan webster 1
                                                @duncanwebster1
                                                DraftSight 2D, it's free for hobby use and is dead easy to use. When I work up te enthusiasm I'll give Fusion 360 a go
                                                #262289
                                                MalcB
                                                  @malcb52554
                                                  Autocad has done it for me.
                                                  Now managed free licensed Educational version of Autodesk Inventor Proffesional which will start putting through its paces over the Winter on a project i have in mind.
                                                  #262291
                                                  John Stevenson 1
                                                    @johnstevenson1
                                                    I use a quite old copy of a 2D CAD program when needed as no one pays me for drawings so I need to spend as little time as possible on them, often they are skeletal in their finished form as long as there is enough for me.
                                                    It's all keyboard shortcuts, virtually never use icons or drop down menu's so it very very fast but I have been using it for years.
                                                    I know from teaching people that different people have different awareness levels as regards spatial awareness and 3D.
                                                    I am fortunate in that I can see things in my mind and actually design shapes that only needs scaling and dimensions when transferred to paper. I think a lot of people can do this but lack trust in themselves. I have seen folk asking for a drawing of a 4 turret tool post after seeing one on the net. Chances are it won't fit their lathe and whats hard about a square block of material with 4 slots in it and a few tapped holes.
                                                    If you measure your lathe up it will give you all the relevant dimensions for you to make your own.
                                                    #262292
                                                    julian atkins
                                                      @julianatkins58923
                                                      I use the insides of cardboard cereal packets and a pencil. Except for boilers which get drawn out properly on A2 or A3 paper.
                                                      My next loco might get drawn out properly, but on paper, if this is still acceptable for ME. It is rather an interesting loco, and might be of interest to ME readers.
                                                      Cheers,
                                                      Julian
