What Did You Do Today (2017)
Home Forums The Tea Room What Did You Do Today (2017)
Viewing 25 posts - 951 through 975 (of 2,518 total)
  • #298377
      Posted by Andrew Johnston on 15/05/2017 20:44:55:
      For the first time in a good few months I've spent some of today working on my traction engines, yippee!
      I've been modelling the check valves for water pump and injector, based on the castings I have. The drawings are largely nonsense. Parts don't fit, many features are not dimensioned and some things are just plain cuckoo. Here is a section of the check valve assembly so far:
      I might even get to cut some metal tomorrow. Back to work on Wednesday, but I think I can get used to these four days weekends. thumbs up
      How do you stop the taper plug lifting off its seat?
      MichaelR
        @michaelr
        Posted by Neil Wyatt on 16/05/2017 08:42:14:
        Gland Packing !!
        #298385
        Clive Hartland
          @clivehartland94829
          Best made like a gas tap, with a washer and a nut on the bottom of the spindle.
          #298454
          matt merchant
            @mattmerchant42413
            nice little donation for the mancave from our metrology department at work, failed calibration tests for them but still accurate enough for home workshop use, diverted from the scrap bin yes
            Matt
            #298457
            Anonymous
              Good question, and one I've asked on another forum. The only answer so far says to pack the gap with something suitable. I wondered if by making the sleeve longer I could use the nut, via the sleeve, to push down on the taper plug. Seems more positive to me? Everything to the left of the ball is at boiler pressure, ie, 170psi.
              I even managed to cut metal for the traction engines this afternoon, first time in nearly four months. sad Of course being slow I only machined a surface and drilled some holes, times four. Note the slow helix drill:
              The first operation to create a reference surface on a casting is always a bit of a "oh eeeer" moment. Get it right and everything that follows is sweetness and light. Get it wrong and one has to fight the misalignment every inch of the way. So worth taking the time to think it through. Especially now that I've converted the 1/4" BSP threads to 3/8" BSP there's less than 20 thou of 'spare' metal to play with on the bosses.
              #298459
                Posted by Clive Hartland on 16/05/2017 09:39:58:
                But then it would not look like the original Burrell one. As MichaelR says the packing holds the spindle down into the taper, Fowlers and Savages also used the same for drain and water cocks.
                Though I would suggest Andrew either makes the tapered pocked a little deeper or spindle a bit shorter so there is nothing to stop the spindle seating down into the taper
                Edited By JasonB on 16/05/2017 19:33:11
                #298461
                Anonymous
                  Yep, thought of that; I'm going to make the taper 'reamer' a bit longer than the taper plug. Whether I alter the CAD model remains to be seen. As long as I know what's going on that's fine. thumbs up
                  #298478
                    Perhaps a thick teflon washer as packing?
                    As an aside today I put 'Davey Arthur' into Google and it came back with a picture of Finbar Furey!
                    Close, but no cigar…
                    David Paterson 4
                      @davidpaterson4
                      Clock wheel marking jig
                      Mounted this on a piece of 42mm thick Jarrah so it sits on the bench.
                      Mind you, I have just finished my second clock before I set out to make the tool.
                      #298492
                      Raymond Sanderson 2
                        @raymondsanderson2
                        Last Thursday when moving the stuff on the patio so the termite spray could be done, I've overworked my shoulder and upper arm muscles. The right the most very little done since then in the workshop with the bench, tried a bit this morning and its going to take a while due to injury.
                        Took a stroll/roll down to see some Jacaranda trees which have been marked for removal by council all residence of the estate bar a few are up in arms they want them left alone. Returned via the canal/water run off path. What a beaut mornin 25C and sunshine in QLD.
                        #298494
                        Benny Avelin
                          @bennyavelin86238
                          My alternator have been making a hell of a racket. Took it apart and found this
                          The black worn part is where the bearing is supposed to sit, not a very good situation. I decided to turn it down from 17 to 16 and see if it worked, but that did not clean up the damaged part. I had to go down to 15.6mm damaging the thread a bit (should be plenty strong anyways), sleeved it and turned it to target dimension.
                          Sleeve pressed on and turned.
                          I wanted to hit a j5 tolerance for an interference fit with the bearing. That is a very tight tolerance -0.002 +0.003 mm, which I hit by the way smiley
                          Now the car is all silent again.
                          #298497
                            Posted by Andrew Johnston on 16/05/2017 19:41:38:
                            Perhaps the barrel of the valve should be parallel?
                            If the packing allows a taper one to lift slightly, it will leak, a parallel one won't.
                            But a taper held down by a spring would be better.
                            #298518
                            Martin Kyte
                              @martinkyte99762
                              Spotted this on the 'Canal alerts system'
                              We are pleased to welcome The Gardner Engine Rally to Huddlesford junction on 3rd to 4th June 2017.
                              I also noticed that they have found an unexploded Bomb next to the canal at Aston, hope it doesn't blow Niel up. He lives round there somewhere I think.
                              regards Martin
                              #298522
                                Posted by Neil Wyatt on 17/05/2017 07:19:05:
                                On the other hand the tapered seating allows a far smaller gap than you would get between a parallel spindle and body so less chance of it leaking in the first place. smile
                                #298541
                                Ian P
                                  @ianp
                                  Why not have the upper part of the spindle tapered so its a mirror image of the valve area? The packing would then be tapered so it both retains the stem and seals it at the same time. What Jason said applies about minimising leak points then applies to the whole stem.
                                  Ian P
                                  Edited By Ian Phillips on 17/05/2017 12:12:42
                                  #298545
                                  Muzzer
                                    @muzzer
                                    Nipped out this morning to get a hacksaw from the nearby Homebase so I could hack the pinion gear off an electric motor. Instead of the traditional Eclipse-type "Junior Hacksaw", I instead opted for the "premium" model with orange frame and soft grey handle. Woo. The label says "this product MUST NOT be sold to anyone under 18". Trying to imagine why not. There is also a "caution" noting that saws by design are extremely sharp. Saves having to take it back.
                                    To make matters more perplexing, the Eclipse model didn't have such a warning. Go figure….
                                    Murray
                                    #298546
                                    Martin Kyte
                                      @martinkyte99762
                                      1. Is this merely a theoretical problem.
                                      2. I thought the whole point of tapered plug valves is that they do not leak.
                                      2b. If you are going to have a double taper why do you need the packing.
                                      Only asking.
                                      regards Martin
                                      #298549
                                      Ian P
                                        @ianp
                                        Posted by Martin Kyte on 17/05/2017 12:38:01:
                                        Only asking.
                                        regards Martin
                                        Good questions!
                                        I would answer 2b by saying that creating and keeping the two female tapers in precise alignment would be a challenge. Both tapers on the stem are most likely going to be machined at one setting so are bound to be truly concentric. By having one taper made of a packing material with compressibility will allow it to conform and make the job much easier.
                                        Ian P
                                        #298552
                                        Ian P
                                          @ianp
                                          Martin K's point about tapered plug valves not leaking is a good one. I'm now wondering why any packing is needed.
                                          If this valve is like the old 'gas taps' with a tapered stem crossdrilled, then there is no reason why any leak is more likely to be 'above' the cross hole than it is 'below' it. Above here refers to the larger diameter taper and below being the smaller diameter.
                                          So if there is no leak (very close fitting taper etc), the stem does not need sealing, it just need to be retained.
                                          Ian P
                                          #298554
                                            The old gas isolating valves typically had a spring at the bottom to keep the tapered spindle tight in teh seating.
                                            As MichaelR stated earlier the gland packing provides the compression (downwards) to hold the spindle down into the taper (as the spring does in a gas valve)and has the added advantage of sealing the spindle (sideways) where it exits the body.
                                            Also allows the friction to be adjusted by how far the nut is tightened so the valve does not close due to vibration while driving along.
                                            #298563
                                            Muzzer
                                              @muzzer
                                              The tapered valve as shown would leak and / or eject when pressure is applied without packing and a mechanical means of retention. Alternatively, to get some degree of self sealing of the taper you could insert the taper from the "big" end of the seat, with the handle emerging from the "small" end of the body and a large cover over the "big end". Of course, it might then prove hard to turn and would be quite a pain to make, which is possibly why they aren't the normal solution.
                                              With valves, there are 2 types of leakage to control – internal (between inlet and outlet) and external (between the internal connections and the outside world. As JasonB says, I suspect that what is being described here as "packing" would be providing both a seal on the shaft and controlling the mating of the taper and its seat.
                                              Murray
                                              #298570
                                                Posted by Martin Kyte on 17/05/2017 10:49:04:
                                                regards Martin
                                                Used to work in Brum for 17 years!
                                                I've taken a cruiser along that canal!
                                                Journeyman
                                                  @journeyman
                                                  I was mostly writing a web page about making one of these:
                                                  It's a flip-up toolholder for screw cutting. Saw it elsewhere on the web and thought I would have a go at my own version. More details ***HERE*** for anyone who would like more info.
                                                    Posted by Journeyman on 17/05/2017 16:21:20:
                                                    It's a flip-up toolholder for screw cutting….
                                                    Thanks John, that ticks one of my boxes this week. Your website's a good'un too.
                                                    #298577
                                                    Journeyman
                                                      @journeyman
                                                      Thanks Dave, as I said not an original idea of mine but quite an interesting and useful tool. J.S. of this parish has a version that uses one of the chasers out of a Coventry die head instead of an HSS bit.
