Warco verses Chester lathes
Home Forums General Questions Warco verses Chester lathes
Viewing 7 posts - 26 through 32 (of 32 total)
  • #272962
    Ajohnw
      @ajohnw51620
      Back to the original question. I haven't bought a lathe or machine off either of them. However I did visit Chester and didn't like the attitude of the sales person I met. I mentioned several problem that can be found on Chinese lathes. He did know about them but the fact seemed to amuse him. Basically I am 100% sure if some one went in and bought there would be no mention of them.
      Being fair though this sort of thing isn't unusual from sales people in any area. None of the these are great, i have one myself that can crop up in other areas though. Sellers do get complaints about all sorts of things that are sold. Fact. It unusual to find a sales person that will point some to another area for this reason. Maybe for another though.
      Scrumpy
        @scrumpy
        Hi I like the idea of solar heating but living in a conservation area and a listed property this is a no no as for insulation there is 2 ins on the wall and 21/2 on the roof but being 20 ft x15 still gets very cold a friend has installed a heat pump but that again is expensive, so my options are a storage heater or a £900-00 lathe from as per the original question Warco or Chester to be used in winter on small items
        #272968
        MW
          @mw27036
          Posted by Ajohnw on 20/12/2016 13:43:59:
          I think I've heard you recount this experience elsewhere on the forum and, to be honest, off the back of your warning I have always avoided using them because of it.
          The warco machines might be just problematic at times, more to do with the maker rather than the seller, but I certainly don't get the same chilly reception from warco, that chester seem to give with their lower prices.
          The machines had things I needed to check out (plastic low gears in the machine broke over time) but there hasn't been any glaringly horrid problems, like spindle alignment.
          My sympathies to boiler bri, that Boxford sure looked the business, and I like you would've thought the chester to be a good like for like match. On a lighter note for him, the size of that steam engine you're building! boy it looks ambitious.
          Michael W
          Edited By Michael Walters on 20/12/2016 14:17:25
          #272974
          pgk pgk
            @pgkpgk17461
            Posted by John Haine on 20/12/2016 09:22:00:
            Anyway, why go underground? B&Q sell 25m of 27amp outdoor cable, armoured, for 25 squids. Run that along a strainer wire above head height. Must be cheaper than underground and certainly cheaper than a new lathe!
            I'm unfamiliar with the regs but does it have to be armoured if overhead? Certainly would need to be weather/frost proof. I used to run 60/70 metres of arctic cable to my greenhouses before the full underground systems were put in and it was fine when in use. there is a legacy overhead cable to a barn here.. again attached to wire.. and not armoured. Yes, good circuit breakers. But I doubt that armoured cable would survive much better if someone drove under with a tall enough farm implement………
            #272977
            Martin 100
              @martin100
              Posted by Scrumpy on 20/12/2016 14:05:08:
              You could go with a totally free standing solar heater if you are permitted a few large diameter (say 3 inch) holes in the structure.
              The levels of insulation quoted, depending on the type, and the levels of comfort experienced may point to something possibly acceptable at some point in the 1960's. Things have moved on a lot since then.
              Twenty eight sheets of 8ft x 4ft x 2 inch PIR insulation is just over 500 quid inc vat delivered. That covers all walls of a 20ftx15ft single level building with a flat roof / internal ceiling. A storage heater at the 2.5kW level is around 250 quid (inc vat) wholesale plus the installation and ongoing running costs.
              A heat pump only brings the costs of daytime electric heating down to gas prices.
              But whatever, without the insulation you are simply throwing money through the roof (and walls and floor)
              Edited By Martin 100 on 20/12/2016 15:26:23
              #272979
              Ajohnw
                @ajohnw51620
                Posted by pgk pgk on 20/12/2016 14:49:40:
                At one time it didn't need to be armoured. Just a catenary wire was fine. Given a typical garage height that aspect wasn't a problem either. I'm thinking of a sloped roof prefabricated garages.
                I'd be surprised if the cable didn't need to be armoured now, resistant to UV and temperature etc.
                Edited By Ajohnw on 20/12/2016 15:54:20
                #273011
                richardandtracy
                  @richardandtracy
                  I have had a Warco WMT300 for 12 years. Much more capable than I am. Prefer Warco as they are nearer and I like green…
                  As for heating – I have an unheated workshop & get condensation. Need, and plan on a brick forge at some point.
                  Heat an old granary with pallets using a Clarke pot bellied stove, got the biggest size so the pallet blocks will drop in whole. Every few weeks I dig out a couple of stone of burnt nails along with the ash.
                  Richard.
