I am considering using an ex Bosch washing motor to drive a small milling machine (Morse 2 spindle). The motor has more than enough power, 300W, but rather more than enough speed at 14,500RPM!
I was going to have a 3:1 ratio using a polyvee belt so that the maximum speed will be about 5000 RPM. Mostly I intend to be using small cutters and was hoping to use the original speed controller so that the spindle can be run hopefully as low as a few hundred RPM.
The motor is a ‘universal’ type and has separate connections for the brushes, field, and tacho-generator and these were wired to its original PCB as is a speed control potentiometer, it must have had variable speed spin or some such feature.
Does anyone know what sort of torque is going to be available at the lower speeds? I have done quite a bit of searching and whilst there is quite a lot of information on ex w/m motors I cannot find anything pertinent to this particular motor.
Ian P
