Using mouldable plastic
Home Forums General Questions Using mouldable plastic
  • #251935
    Roger Hart
      @rogerhart88496
      Recently used some mouldable plastic – where you tip granules into hot water and get a mass of clear plastic. Useful stuff but I found hard to manage.
      Are there any easier ways to use this than attempting to handle a hot, incredibly sticky mass. I did my job OK but found avoiding blowholes and water pockets a bit of a problem. Even getting the stuff off swmbo's saucepan and ladle was a problem.
      #24696
      Roger Hart
        @rogerhart88496
        #251941
        David Colwill
          @davidcolwill19261
          Search for Formcard. There was a post on here about it not long ago (thanks Fizzy),that's how I know about it.
          David.
          #251946
          Douglas Johnston
            @douglasjohnston98463
            You don't need to use hot water, I have found a hair dryer works well but you have to contain the granules or they blow all over the place until they start to melt and stick together.
            Doug
            #251949
            MW
              @mw27036
              Why not take this a step further and isolate the water and plastic from each other? boil a saucepan and place a glass bowl over it, let the steam heat the bowl and let your granules melt into that instead?
              Buy a cheap pyrex dish from wilkos or wherever and keep it for the granules.
              Michael W
              Edited By Michael Walters on 23/08/2016 09:22:01
              #251955
                I think you are right track, Michael yes
                … Re-inventing the traditional wood-workers' Glue Pot.
                Roger Hart
                  @rogerhart88496
                  Thanks for the replies all. I think I was heating up too much. Instructions said boiling water which is probably a bit too hot, as the stuff cools down it gets more tractable and less sticky. Other instructions say 60 degrees C which looks more sensible. I'll know next time….
                  #252167
                  Georgineer
                    @georgineer
                    You've got the answer! It works well at 60*C but if you go much hotter it actually melts and acts like hot melt glue. There is a lower temperature version available as well – in one of my jobs we used it to make personalised pencil grips and the like for disabled children. I've never used it for any precision jobs though.
                    George
                    #252207
                    Ady1
                      @ady1
                      I always clean out and hang onto those microwave food dishes because they are fine up to boiling point and can be used for any guffy jobs which crop up
