Use of Torx Bits in Hex Skt Hd Screws
Home Forums General Questions Use of Torx Bits in Hex Skt Hd Screws
  • #469540
    Tim Hammond
      @timhammond72264
      In several YouTube videos recently, including one by Clickspring this morning, I've noticed the use of Torx bits in cap head screw rather than the usual hexagon bit. Intrigued by this, I tried a series of Torx bits in various screwheads and found they fitted far more snugly than the hex bits, especially Torx+ bits. Does anyone else use Torx bits in these applications?
      Tim Hammond
        @timhammond72264
        #469541
        Ian Parkin
          @ianparkin39383
          I have found that a damaged hex cap head responds better to a torx bit hammered in to remove it
          #469570
            A couple of thoughts:
            • A good quality hex key, the proper size for a good quality socket screw should be entirely adequate.
            • A Torx driver will, inevitably deform the socket in a poor quality screw if much torque is applied
            That said … Ian makes a very good point.
            Vic
              @vic
              You can buy Torx cap head screws, are you sure it wasn’t one of those rather than a Hex drive?
              #469603
              Tim Hammond
                @timhammond72264
                I don't think so, I've just had another look at Clickspring's video (Using a dial indicator to set a 44* topslide angle), and all the threaded fasteners shown on his lathe look to be ordinary hex socket head cap screws. Have a look and see what you think. (I may be mistaken, wouldn't be the first time!)
                #469692
                Steviegtr
                  @steviegtr
                  Torx is the way to go as long as the bolt is good quality & the tool is too. Most car manufacturers are using them now.
                  Steve.
                  #469816
                  old mart
                    @oldmart
                    It is useful to know that Torx bits could get a hex screw moving if it is damaged.
                    #469830
                    Grindstone Cowboy
                      @grindstonecowboy
                      I could be wrong, but it looks to me like it's just a hex key with shiny corners, not a Torx bit, and they are ordinary hex-recess cap screws?
                      Rob
                      #469834
                      I.M. OUTAHERE
                        @i-m-outahere
                        I think you will find the Torx bit is only driving on the tips and in a high torque situation will fail – a bit like a 12 point socket verses a hex socket on a hex bolt or nut . There is a reason why impact sockets are all hex design .
                        #469846
                        Mick B1
                          @mickb1
                          Posted by XD 351 on 07/05/2020 14:46:45:
                          +1. When they work well, it's because Torx bits are *usually* decent steel, where hex keys explore the full spectrum of quality from end to end…
                          wink
                          #469848
                          Enough!
                            @enough
                            Posted by Tim Hammond on 06/05/2020 11:22:32:
                            I went to youtube . Clickspring > videos > sort-by-date-latest and the latest listed was 7 months ago.
                            I link would be helpful.
                            #469869
                            Oldiron
                              @oldiron
                              Clickspringclips      It's on his second channel.
                              regards
                              Edited By Oldiron on 07/05/2020 17:50:04
                              #469879
                              Robert Atkinson 2
                                @robertatkinson2
                                That video shows a hex key in a hex cap head. Key is polished on the corners that mkes it look a bit like a Torx.
                                Right bit of quality make is best. Identification can be an issue I have hex in metric and imperial (down to 0.035&quot, Bristol Spline, Torx, RIBE TS and various vehicle size spline bits.
                                Robert G8RPI.
                                #469886
                                KWIL
                                  @kwil
                                  Polished corners also allows access at an angle as the toolpost obstructs a clean vertical approach to the cap head, there are of course hex drivers that have the necessary shape to allow angular offset.
                                  #469887
                                    Posted by Mick B1 on 07/05/2020 16:12:51:
                                    For one end of that spectrum It’s worth looking at p33 [= p35 of the PDF] here: **LINK**
                                    http://www.unbrako.com/images/downloads/engguide.pdf
                                    The other end is Cheese, I believe
                                      Just out of interest, a torx bit is designed to make the turning force more nearly tangential to the faces of the bit.
                                      Sadly using a torx bit inside a hex hole does not provide the same advantages as using a 'lobed' socket on a rounded hex.
                                      Vic
                                        @vic
                                        Posted by Grindstone Cowboy on 07/05/2020 14:29:50:
                                        Rob
                                        Yes, I had a quick look and it was as you say, an ordinary hex bolt and driver, the driver just had shiny corners.
                                        #470062
                                        Pete Rimmer
                                          @peterimmer30576
                                          Anyone who works regularly on Japanese motorbikes more than a few years old knows that if you round off a socket head because of ill fitting/corrosion/poor quality fastener or reduced engagement due to road filth or corrosion, beating a torx bit into the hex will almost always get you out of lumber. The combination of hammering to break the bond and the firm fitting of the torx will often cause the thread to release (or the tool to break) before it will cam out or round off.
