Unusual Crow Bar Type Tool? Fire Brigade?
Home Forums Help and Assistance! (Offered or Wanted) Unusual Crow Bar Type Tool? Fire Brigade?
  • #801679
    Martin King 2
      @martinking2
      Hi All,
      Been away from here for a while as we have been very busy!
      Here is this weeks mystery tool that came in with an auction lot, very nicely made but no makers marks at all!
      380mm long overall, beautifully made latching mechanism for the fold out serrated jaw:
      fireman 1fireman 2
      fireman 3
      Mark Easingwood
        @markeasingwood33578
        No idea, but it looks a bit “surgical”.
        Is it stainless steel?
        Mark.
        #801702
        bernard towers
          @bernardtowers37738
          Mountaineering???
          #801710
          Robert Atkinson 2
            @robertatkinson2
            Looks well made and light weight. Might be a a military aircraft escape tool. For opening sliding canopies or similar.
            Robert.
            #801713
            Diogenes
              @diogenes
              I’d go for mountaineering too..
              #801748
              Martin King 2
                @martinking2
                Made of Aluminium with hardened and ground serrated jaw and curved tip. We get a lot of ice axes etc but never seen a mountaineering tool like this?
                #801749
                Martin King 2
                  @martinking2
                  Should mention that the jaw stows inside the shaft on a spring release and lock.
                  #801830
                  Plasma
                    @plasma
                    Definitely not for climbing, there is no attachment point for a sling which is essential, grip strength is not enough to hang onto an ice axe, no matter what Hollywood tells us lol.
                    Also the jaw is too short and not pointed enough for ice use.
                    I’m tending toward the aircraft tool, but only because Trumpton don’t have such skinny tools for rescue, they tend to go overboard with such kit, like six foot wrecking bars.
                    The curved jaw could also only be used to lever against itself, not the head of the shaft, like a heel bar, because of the spring release knob. Note th rearward facing set of the teeth too which woukd work with this kind of use.
                    #801850
                    Zan
                      @zan
                      I had an ice axe with a head pick at this angle in the 60-70s the serrations are designed to hold but are too shallow . I modified mine with rapid oxy acetelene  heating to bend it steeper. Then very effective !but replaced when I could afford it.   The shaft was wood and not strong. Hamish Mc innes first introduced a metal axe with a Hinduminium shaft, made in his back garage my dad was a good friend having supplied him with walkie-talkies for an early attempt at Everest face climb.
                      However even on this home made device the curved spike would be useless, serrations  are far too small to hold in ice  Seems to be a cross hole for a strap, but at wrong end and too small.
                      Does the pick foldaway by a screw lock at the top, or is that where a lanyard could be attached?
                      i go for a geological tool to dig out rock samples
                      #801923
                      duncan webster 1
                        @duncanwebster1
                        The pick end of my ice axe was a lot longer than that, cant see that being effective at stopping you  when you’re sliding down a steep snow slope
                        #801965
                        Tomk
                          @tomk39956
                          It could be a tactical version of halligan tool also known as a hooligan tool which was used by fireman.
                          #802179
                          Martin King 2
                            @martinking2
                            Pulling out the screw at the top allows the jaw to unlatch and fold away with a spring retainer on the side to hold it locked. My gut feeling is fireman related also but Google lens shows nothing for it?
                            #802214
                              I vote aircraft.   Looks like an expensively made lightweight short pry bar with no provision for a carrying strap – not portable up mountains.  Robert suggests an escape tool for use on sliding canopies; I’m thinking cargo planes for adjusting pallets and strapped down loads.
                              A naval friend had a “fun” experience many years ago.  Taken ill in Gan, he was flown back to the UK for surgery in considerable pain, getting worse as time passed.  When the plane got to Cyprus it circled the island for over an hour, no explanation, presumably burning off fuel.   Then the crew appeared with a toolbox and his group were made to sit in the aisle.
                              The crew unbolted seats to lift a section of floor so the could try and wind the jambed undercarriage down manually.  They took turns to heave on it, unsuccessfully at first.  Though they eventually got the wheels down, all the passengers were fully expecting to die in a crash-landing.  Toughs wept whilst writing their wills and farewells etc.   My friend reckoned he was the bravest man present – in so much pain that he welcomed death.
                              Maybe a small pry bar was used to lift the floor-plate.
                              robt
                                @robt
                                Hi,  I don’t know exactly what it is but I have one too!  See pictures.
                                I found this post via Google Lens and it is the first time it has given me a proper match despite trying a few times over the past couple of years.  I am trying to find out what it is as well.
                                I am a Firefighter and into historic items.  I purchased this as it was sold as a folding hooligan tool (which is a forceable entry tool used by firefighters etc).  However I am sure it is not.  As suggested above the release knob would get easily damaged.  For the same reason I don’t think it is an ice axe.
                                It does have a lanyard hole but assuming mine is original (which it looks like it is) it is to secure a leather cap that protects the fixed crowbar end.  Mine also comes in a webbing holder that again looks original.
                                So any more ideas now after seeing mine?
                                Rob
                                20230831_21535420230831_21533620230831_21543220230831_21545820230831_21550920230831_21551920230831_215535
                                #809372
                                robt
                                  @robt
                                  Actually after comparing more closely the folding ‘pick’ element of the two have slightly different profiles and mine has a thumb notch as well!  It is extremely well engineered.
                                  #809376
                                  Ian P
                                    @ianp
                                    I think the reason Rob’s has different profile is because it been deployed (maybe not for its intended purpose) and the serrated ‘pick’ has been strained and bent.
                                    I think the pick is meant to sit flush and be lifted out with the penknife-like thumb notch.
                                    Ian P
                                    #809379
                                    Macolm
                                      @macolm
                                      I think they are the same item, the original post a slightly improved later version. The “pick” on the later posted version has probably bent in use, hence the profile would be strengthened at some point during the producton run.
                                      #809383
                                      Nigel Graham 2
                                        @nigelgraham2
                                        I’ve just extended the enquiry to a friend who is a retained fireman.
                                        #809397
                                        Charles Lamont
                                          @charleslamont71117
                                          For getting bent car doors open?
                                          #809489
                                            I have seen similar tools used for ‘inching’ machine tools into alignment, although this appears to be a deluxe version.
                                            #809512
                                            Nigel Graham 2
                                              @nigelgraham2
                                              That size looks too light for manipulating a complete machine, surely, but might be for setting individual, lumpy parts?
                                              #809653
                                              Martin King 2
                                                @martinking2
                                                Hi All,
                                                I have made as many enquiries as I can about this tool with no further light being cast on it.
                                                It is now sold and the buyer is away for a week or so and I will ask him about it when he gets back.
                                                Cheers, Martin
