With Dave really. Perhaps not as exteme as Martin.
Iron requires air and water to rust. We cannot remove the air but can keep the surfaces free of moisture. Either oil/grease or warm enough to prevent condensation. Dew point depends on relative humidity reaching 100% and condensation can occur on any surface at zero Celsius.
I have partitioned off about 14m^3 for my machines at present. Well insulated and sealed – I mean very draught-proof – so air change with the door closed is vey minimal and only at low level.
Since January – to date – it has cost me about 5p per night to keep things warmed a little and quite dry. Initially it was costing about 10p per night to run a desiccant dehumidifier for three hours. Likely drawing moisture from the concrete floor until dried out. I am now running it just an hour each night, costing just over 3p I think.
The humidifier collects water and warm
s the area sufficiently to keep all metal surfaces dry. The machine working surfaces are lightly oiled, just as if in use. Later in the year a compressor type dehumidifier would be better (over 15 degrees and less heat produced) but I expect I will need ventilation while working in there, anyway!
I was contemplating fitting a fridge in the partition wall for summer cooling, controlled by an STC1000 at rather higher temperature than the normal fridge thermostat. That would act as both dehumidifier and heat pump. The running costs could be minimised by solar generation.
(LED) lighting is clearly required at all times of use but again solar generation can normally be used to keep grid power consumption down. I don't have a suitable wall for conversion to solar air heater, but the insulation is quite good for a sectional concrete garage.
I plan to increase the volume to about 18m^3 this summer if I can manage it. The only real expense being the reticel insulation for lining. The rest is chicken feed, cost wise – three or four scrap garage doors (easily found), a couple rolls of 150mm rock wool insulation and a length of angle iron (both items on site already).
I purchased two 'dead' dehumidifiers for less than a hundred quid; one works perfectly and the other only on one of the two 'speed' settings. I am using the less than perfect one. Reticel cost around £200. Payback time cf a 60W bulb running 6 months of the year? About a year, I would guess! Worth it, I think!
edit:the last 'paragraph should have been four or five. This is the only forum where the post is compressed like this!
Edited By not done it yet on 09/05/2017 01:30:15
